Old 24th September 2012, 06:13 PM
I was going to, but someone's left half a Triumph Spitfire in there!
well, as a two car garage with "half a Triumph Spitfire" in it there should be space for 1.5 cars then? i.e. just about right for an 8.
Old 24th September 2012, 07:20 PM
With friends like this....
Old 24th September 2012, 08:20 PM
47p2's Avatar
47p2 47p2 is offline
Guilty as charged m'Lud
Nite Blue 3.0L SE Quattro
Old 25th September 2012, 09:19 AM
sloss's Avatar
sloss sloss is offline
I'd be embarrasesd to post a pic like that. What does the chauffeur do all day.....?
Careful how you answer that.....
Old 29th September 2012, 12:33 PM
Default Four mysteries
OK, back to the boot lock...
I've replaced the vacuum driven 'actuator' that applies the central locking to the boot, but to no avail. The actuator works fine if you blow/suck (don't you mucky lot start again!) but nothing happens when the central locking is activated. BTW, there are no electrical connections here and just one pipe connection.
So, I went on the hunt to trace the pipe back the the central locking pump. First mystery was that the pipe from the boot lock disappears into a wiring loom behind the pump (photo 224 - the black tube at the bottom of the photo), so I have no idea where it goes from there.
Second mystery was a tied up pipe (see photos 225 and 226). There's been a rubber pipe added to the harder plasic pipe which has then been folded over and cable tied, apparently to seal it. But this isn't the pipe that goes to the boot lock. And I couldn't find where this might have originally been connected. But someone has clearly been here before, as the pump wasn't in the right way around (it should be upright with the wiring at the top and the 2 green pipes facing the rear)!
So the boot lock still doesn't work fully!
Anyway, 2 more mysteries still to come. In picture 227, why are there so many cables going nowhere?
And in picture 231, what's the red pull cable for? It's in the fuse compartment above the battery and it moves when you lock the car. At a guess, it might be an emegency unlock, but I wasn't brave enough to pull it too hard, in case that's not correct.
All thoughts welcome!
ID:	4891   Click image for larger version
ID:	4892   Click image for larger version
ID:	4893   Click image for larger version
ID:	4894   Click image for larger version
Old 29th September 2012, 01:08 PM
47p2's Avatar
Is the red pull cable not the to open the fuel flap in an emergency?
Old 29th September 2012, 01:13 PM
Correct, so if the Central locking pump fails you can still unlock it to fill up......
Old 29th September 2012, 03:57 PM
Do you get any suction on the pipe when you activate the locking?
Old 29th September 2012, 04:07 PM
So, simple question, when you activate the central locking does the pin behind the fuel flap move in and out, thus unlocking/locking the flap?
I'd guess from the fact that the red emergency release moves that it does.
The would show that the vacuum pipe is intact and working up to that point; I believe that then leads on to the boot via the grommets (that are giving me and Mannyo some grief) in the offside wing and boot near the boot lid hinge mechanism.
All that tied up plumbing suggests someone has had a problem and sealed up the end before it gets to the boot lid. I would imagine it can be fixed by splicing in a new section (with suitable reinforcement) unless the leak is in a difficult area. A bit of sucking and blowing on opened-up pipe ends would probably trace that.
Old 29th September 2012, 04:30 PM
They just look like unterminated AV input leads. Without knowing exactly what you've got in that stack of kit I'd say someone maybe once had an extra aftermarket unit of some sort in there, such as a DVD player feeding into the TV Aux input?
Mine looks pretty similar awaiting connection of my DVB-T tuner.
Back over on the "plumbing" side as I was in the boot anyway I had a quick look at mine just through the access panels and the plumbing to the boot lid after entering the body through the grommet turns forwards and disappears behind the fuse carrier. How it then connects to the pump and/or plumbing to the fuel flap release I can't see.
