Old 25th September 2012, 02:54 PM
Sadly not, this is more comprehensive: http://www.citruscables.com/Products...tionChart.aspx
And they look quite like MCX, but I think they're slightly larger.
Old 25th September 2012, 03:10 PM
are they not Fakra cables?
theres different types, but are these them
Old 25th September 2012, 03:48 PM
Correct, they are not.
(Also, I think Fakra connectors are actually a family of connectors based on an SMB core with additional colour-coded latching surrounds - this is definitely NOT SMB)
Old 26th September 2012, 03:30 PM
he's found another lead design with a slightly larger push-fit connector
Sadly that was just the other SMA (male vs female) so the two leads join happily end-to-end but not to the loom in the car.
Any further thoughts anyone, especially the "experts" at A8parts? I really don't want to have to cut these rather short cables and do any soldering inside the boot.
Old 26th September 2012, 03:52 PM
Have you tried the local Audi "parts expert" also?
Old 26th September 2012, 04:00 PM
Do you mean the guys at Amersham Audi?
Old 26th September 2012, 05:48 PM
Yes I just wondered if they could tell you more about the adaptors they used *shock horror* lol I expect not but you never know!
Old 26th September 2012, 08:39 PM
Ian, having done that can you comment on:
1. Are the aerials passive or active (powered)?
2. Where (roughly) are the 4 I have and which would you use if limited to 1 or 2?
1) I dont know and wouldnt want to guess
2) There are two at the very back of the parcelshelf under the window, and 2 up the sides. My understanding is that they are all in different places at different angles doing the same job and the diversity tuner switches between them dynamically to use whichever one has the strongest signal. I wouldnt ever use just 1 or 2.... There are 4 for a reason
Read this from about half way down the page onwards, it might help:
http://forum.a8parts.co.uk/showthread.php?t=1544&page=3
Old 26th September 2012, 08:42 PM
Concur - As a last resort, you can break off the plastic outer and use the SMB 'raw' to plug in quite easily. The fabra connectors are different colours, and its not just to be pretty. Easy connector is keyed on the inside so it only fits the correct port. GPS, DAB, FM, TV, Phone - They all use these with different connections...
Old 26th September 2012, 08:43 PM
Next .................. Phantom Aeriel
Just out of interest, what phantom aerial are you planning to fit and do you have the leads?
Reason I ask is that as a result of my own failed attempt (SO FAR) to "phantom" the PF OEM "unidentified connector" TV aerial into my new DVB-T unit I have some spare leads that I was going to send back for a refund.
However, they may be suitable for the FL model TV aerial leads as they're different (more "standard") and the vendor was convinced they were correct as he had fitted some.
PM me if you are interested or want details.
