Old 5th October 2012, 05:33 PM
Zip's Avatar
Zip Zip is offline
Question Weak windscreen washers...
All,
My windscreen washer pressure has suddenly become very weak. No leaks from the pipes at the screen (push fit has popped off in the past) and no leaks I can see anywhere else. I descaled all the nozzles not long ago so they're OK. Any ideas? Is the pump on its way out? Easy to replace?
Thanks,
Zip
Old 5th October 2012, 07:08 PM
47p2's Avatar
47p2 47p2 is offline
Is there any one way valves on the system? I know Saabs suffer from faulty valves which cause low pressure at the jets
Nite Blue 3.0L SE Quattro
Old 7th October 2012, 10:29 AM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
I am also having this problem but I've had it before and I replaced the pump when I needn't have. Last time I noticed the little mesh filter under the pump had been clogged up with algae type stuff.
I suspect that's what's happened again but I'll update once I've had a look. It's a wheel off, arch liner off job.
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 7th October 2012, 10:31 AM
A8L Chick's Avatar
Mine is D3 but I can't imagine them being too different.
Old 7th October 2012, 11:05 AM
Zip's Avatar
Zip Zip is offline
Thumbs up
thanks - I'll have a look.
Zip
