Old 10th October 2012, 02:10 PM
barzya8 barzya8 is offline
Default Replacing cruise and light stalk
Hi everyone.
I am hoping someone can advise me which part number I require for my 1997 4.2 QS.
The car was 1st registered on 14th April 1997.
The part number choices I have to hand are as follows.
4D0 953 513C which seems to be for early 1997
or 4D0 953 513M which seems to be for late 1997
Any help would be greatly appreciated
Thanks
David
Guildford, Surrey
Bose sound system.
Audi Navigation Plus.
20 inch Final Edition alloys
Old 10th October 2012, 02:22 PM
I went round that loop a while back, there was a way to tell IIRC from looking carefully at the existing stalk.
HOWEVER in my case the problem was elsewhere and eventually solved another way; what makes you think you need to replace it?
Old 10th October 2012, 03:34 PM
C is up to 07/97, M is from 08/97
Old 10th October 2012, 10:56 PM
Someone get this man a
Old 11th October 2012, 08:31 AM
Thanks Guys,
Looks like the one I have got is the wrong one then
Guildford, Surrey
Bose sound system.
Old 11th October 2012, 08:33 AM
What problem are you trying to solve though, or is it visibly broken?
Old 11th October 2012, 02:33 PM
Hi HPsauce,
Cruise control worked intermitantly when I got the car last year, then stopped all together. Tried cleaning the contacts for quite sometime but this made no difference. Saw this 6 month old light and cruise stalk being advertised by one of our forum members on e.bay (jeremyp) and decided to buy. Now I think I have the wrong stalk after reading the audipages instructions for replacement as they state there are two types for the 97 A8
Guildford, Surrey
Bose sound system.
Old 11th October 2012, 02:43 PM
Similar symptoms to me, the problem was the well-documented "dodgy capacitor" problem - fixed by replacing the cruise ECU.
Old 11th October 2012, 02:50 PM
Where will I find the cruise ECU or the sticky to show me?
Guildford, Surrey
Bose sound system.
Old 11th October 2012, 03:08 PM
It's a cigarette-packet sized metal box in the waterproof box full of ECU's under the bonnet - nearside by the bulkhead and wheel arch.
Unfortunately it's right at the bottom under several others.
I bought one from A8parts (not expensive) had a look in the box and gave up; paid a local Audi specialist to swap it over.
I decided that it was the controller not the stalk after doing all the things everyone else did and realising it randomly stopped without me touching the stalk at all. Not only that, it either worked or didn't - just not consistent with dirty switches.
I'll see if I can find the thread....
EDIT: Have a read here: http://forum.a8parts.co.uk/showthread.php?t=113 it covers most of what you want to know, even what I paid the garage!
You'll note that I had had my stalk replaced once (professionally) a while back - I think that was a genuine switch fault as "some" functions worked. Then the box was the next problem
