Old 25th October 2012, 11:33 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default RNS-d Tuner Coding.
Afternoon.
The tuner box and RNS unit came from the same car, I believe the tuner was coded but going by the AS+Down Arrow menu it's not coded.
Is this a simple case of plugging in the Tuner box, VCDS and coding it in?
If it is, how do I code it in?
I'm not that familiar with VCDS for coding.
Old 25th October 2012, 01:22 PM
you should find all you need on this site
you can code through either the radio or the satnav, work out your coding dependant on the equipment you have in your car
http://wiki.ross-tech.com/wiki/index...A8/S8_%284D%29
Old 25th October 2012, 05:55 PM
ScottD3's Avatar
Thank you.
I found a link to the old sat nav site.
I think I found in there.
Thanks.
