Old 12th November 2012, 07:35 PM
chie chie is offline
Default a8 d2 4.2 qs for sale, good price?
hi as you might guess from my introduction thread i got this car a few weeks ago and basically the gearbox has gone into limp showing the fault incorrect gear ratio, sadly i dont have the funds to throw at the car to fix it
starts and drives but is in limp so reverse and forward and no tip
it has 6 months tax
mot till june next year
full tank of fuel
full bose system, probably standard on all a8`s?
black electric front seats and non heated or adjustable rear
detatchable towbar
lots of regular stamps in the service book,
normal sunroof
2 keys and a valet key
on a whole a clean car, a few scratches here and there, a cracked front lamp and rear lamp
the leather has no wear on bolsters supprisingly as it has covered 96000 miles, and all adjustments work fine inc headrests
im asking basically half what i paid i have searched a few threads but i cant really find what these go for with a dodgy `box,
im asking £1000 but am open to offers if this is way to high? just trying to claw cash back to fund a replacement
best get me on email as i can reply at work, richie _ d3 at hot mail dot com
car is located in south shields tyne and wear thanks
ID:	5260   Click image for larger version
ID:	5261   Click image for larger version
ID:	5262   Click image for larger version
ID:	5263   Click image for larger version
ID:	5264   Click image for larger version
ID:	5265   Click image for larger version
ID:	5266   Click image for larger version
Old 13th November 2012, 10:19 AM
I'd maybe risk a 150 quid on an oil flush, or maybe just top up before getting rid.
Old 13th November 2012, 11:15 AM
Probably not worth oil change but do check level first and top up if necessary.
Old 13th November 2012, 11:30 AM
sloss's Avatar
sloss sloss is offline
Does Richie know how to check and top up the oil - there's no dipstick and you need a pump with a flexi arm.
It's prolly covered in the Mechy bits someplace..............
Old 13th November 2012, 12:05 PM
Did you rule out the F125 switch? I'd get a proper diagnostic on this if I were you. Aren't you Glagow based? If so, A4 Audi in Clydebank have the full gear and usually don't charge for a diagnostic. IIRC, my F125 switch was specified on the check.
Old 14th November 2012, 11:19 AM
topcyclist topcyclist is offline
What is the F switch ? I suspect I have a gearbox problem coming up ...was planning an oil flush .
thanks Steve
Old 14th November 2012, 12:03 PM
The F125 switch aka the range control switch/multi-function switch is located on the side of the gearbox - it has a mechanical component to it which takes an input from the mechanics of the gearbox and then converts that into an electrical signal to the gearbox ecu to confirm that the mechanical side of the gearbox is doing what the electrical side asks of it. It links to cruise control as well, I seem to recall.
Note there are 2 versions (8 and 10 pin connector) which varies depending on gearbox code
The weakest part of it is the connector, hence the advice to try cleaning it up, but it's a bitch to get to. The part itself isn't astronomical (around £150) but it does involve dropping the gearbox down to reach it.
Symptoms (aside from logged faults) are limp mode when going from d to r and back again when parking/first started, but otherwise generally good behaviour if you manage to set off on a journey without it going into limp mode.
Mine was definitely faulty and haven't had any repeats of issues since changing it. I suspect it is rarely the cause of a fault where the gearbox itself appears to be banging/not changing/slipping as there are all mechanical faults.
Old 29th November 2012, 08:13 PM
oldnick oldnick is offline
what happens if you put it in manual and drive it like that ?
if it would take you to glasgow for a free diagnosis ......
several people have been known to drive like that for a lot of miles !
Old 1st December 2012, 04:00 PM
SyncroS8 SyncroS8 is offline
Sounds like the normal failure of a bearing and then the O-ring so Clutch pack A gets no oil pressure.
I have a Phaeton W12 atm with the same problem and after having fixed one of these gearboxes in my old S8 (now driving around in another S8) I'm finding it hard to get enthusiastic about pulling the Phaeton gearbox out. It's the same design of gearbox.
Does it work properly when the gearbox is stone cold for the first 30 seconds? My S8 did and then failed where as my Phaeton tried to creep forwards in 1 pitifully before going into Limp mode.
Yet another 5HP24 that needs work
MG
