Old 15th November 2012, 05:58 PM
chie chie is offline
Default so i took the car out after calming down...
cleared the code on gearbox, took it out for a run around the block,
goes into d and gives a little tug as to say it was engaged,
so i set off, it revs and clunks into limp, so took it around the block, got back and plugged the laptop in and using vagcom got the codes:
g28 engine speed sensor implausable intermittant
incorrect gear ratio
so thinking logically about this, the trans and engine need to know what they are doing to match clutching to rpm?
and the way i am thinking about it is if the trans doesnt know what rpm the engine is doing it cant engage as it cant see if the engine is at idle or say 2k?
or am i just clutching at straws?
any advice would be great as i have no idea about auto transmissions
Old 15th November 2012, 06:07 PM
Well 2 problems at once is always tricky, but go for the easiest/cheapest first.
Old 15th November 2012, 06:09 PM
it's ****ed - budget on a rebuild. The engine management isn't that clever - it's just seeing implausible numbers that don't match because the engine is revving, the speed is too low for the revs, most likely because something in the box isn't engaging properly so think torque converter or something else internal to the gearbox
Sorry
Old 15th November 2012, 06:10 PM
LOL - 2 different answers, one from an optimist and one from a pessimist
Old 15th November 2012, 06:12 PM
ah so based on that (right or wrong) the fact it engages and feels like the clutch slipping then the clunk and limp can possably say some sort of clutch is fubar :S
great... i wouldnt mind if i had absloutly spanked the car and abused it, i could expect it to go wrong then...
like the 2 answers though lol
Old 15th November 2012, 06:14 PM
Not really, a speed sensor is a speed sensor.
If it's on the engine clear it (if you haven't before) and see if it returns.
Whether it affects the gearbox I've no idea.
Old 15th November 2012, 06:23 PM
i give up i cant afford a rebuild and the trader i got it from is saying well it was fine when i got it so he cant help.... then started on about my trade in costing him 1200 quid and do i want to pay that,
sick isnt the word
Old 15th November 2012, 08:19 PM
How long ago did you purchase it? A friend of mine bought FTO and after couple of moth engine gave up, dealer refused to do anything but after complaint to consumer protection or whatever it is called they paid for a second hand engine to be installed.
Old 15th November 2012, 08:39 PM
Amanda Amanda is offline
If you buy from a car dealer IIRC you have 3 mths to sort any probs out
Old 15th November 2012, 09:30 PM
3 weeks ago, bloke was a registered trader but used his house ti trade from
