#41
Thanks I'll have a check through everything tomorrow
![]() Richard - Thanks same drop off as collection, I'll PM if Wednesday looks dubious, but I'm sure it will be fine ![]() Adam |
#42
Today I appear to have a fully functional sat nav again
![]() I don't have Bluetooth though. MMI tells me I have no phone, my sgs3 cant detect the Audi module. This seems to be related to the update as it was working fabulously beforehand. There doesn't appear anything i can do. I have tried pairing using two other phones but they aren't detecting the Audi unit, and of course the MMI says there's nothing installed anyway. Could this be recoverable via Vagcom....or is the unit toast....has anyone got any experience ![]() I have tried running all the discs again, none of them are picking up anything to update. I must have attempted to run disc 2 about 10 times (in different slots on the changer as well) but no joy. TIA Adam |
#43
Well I am back in the car for the fourth time. Two attempts with cd2 in slot 1 of the changer did nothing. Then slot2 immediately picked up an update for Handyvorb2/MAIN6/App to upgrade rom 0 -1130. Fingers crossed.......
#44
Fingers crossed
#45
Success
#46
Okei, i have updated to 5570 version but i cannot see the Battery Level. Any suggestions?
#47
you need to turn it back on - it gets taken of as standard in the latest version as it was thought to be not that good
to turn it on you need access to the hidden menu you only have access to the hidden menu if its been enabled in vagcom try it though you may be lucky You press CAR + SETUP at exactly the same time and hold for a few seconds until a green hidden menu appears once your in go to car menu mask then scroll down to find the battery meter click it so a tick appears scroll down and save reboot using TEL - MAIN BUTTON and top right button and it should be there be careful using anything else in the hidden menu it can be dangerous
#48
Alright, i have tried several times CAR + SETUP but nothing happens. Seems like i have to activate it with VCDS. I have VCDS interface but i don't know how to activate the hidden green menu.
Also i have seen that the parking sensor are being audible only but not showing on the display. Perhaps using same hidden green menu i can bring this feature to life as well. Many thanks! |
#49
not sure about the parking, will take a look
heres the vcsd bit http://www.audi-resource.com/mmiaccess.php
#50
there is something about parking in there
under DIAG SETTINGS then APK 0×01, 0x0B, 0x0C these 2 settings - you can also do it in vagcom APS (front) - activation parking sensors front of the vehicle. Equivalent adaptation module 07, channel 1, the value 4 APS (rear) - activation parking sensors in the rear. Equivalent adaptation module 07, channel 1, the value of the 8th
