Old 4th February 2013, 07:10 AM
Mackies in Glasgow did mine and Brian's for about £150
I think that the point is, Jim, what did they do at Mackies for that money?
Did they drain the oil and replace what drained or flush through which uses 11-12 litres? Did they replace all parts like washers and o-rings? did they clean out the magnets and then clean the sump off and re-paint it etc?
I'm not saying its not good value there, I'm just saying what do you get for your money there vs Chester Transmissions and what costs do they have at each for parts, especially gearbox oil, as the "suckypumpysquirtythingummajig" uses more that the system will hold in flushing ALL the fluid through and replacing it!
Old 6th February 2013, 05:04 AM
I thought Brian might have been along with the details. We definitely got a flush and filter change and Mackies had it on the invoice as a 'gearbox service'.
Old 13th August 2013, 10:33 AM
Drove 200 miles up north to Chester Transmissions (http://www.transcentre.co.uk/) and did the 'Service Plus'.
Apart from Chester is there anyone else in the country that does this? That web site only seems to have a front page now.
A brief discussion at AITP suggested someone near Weston-Super-Mare but that led me to JP Auto Transmissions who only do parts and hadn't heard of the process.
Old 13th August 2013, 10:52 AM
The ZF Service partners are included on this page:
http://www.zf.com/corporate/en/produ....jsp?region=EU
I have also seen (somewhere) on the ZF website mention of approved associates including Chester Transmissions and Mackies.
Old 13th August 2013, 07:35 PM
Try http://www.colpax.co.uk/ Andrew the website is non-existant but Im told that they have the tech-tronix suckypumpysquirtythingumabob machine and I'd be interested to hear if that is the case and what prices as they would be nearest to me also
Col-Pax Motor Engineers
Winterstoke Road
Weston super Mare, BS23 3YS
Phone: 01934 416923
Old 13th August 2013, 07:48 PM
That's useful to know as it's local to my parents and labour rates are always buttons compared to this neck of the woods!
Old 14th August 2013, 04:20 PM
As noted in the MOT thread I'm now just going to have a "standard" gearbox drain & refill as it's going to be combined with sorting out leaky output shaft seals and the seal on the pan is also leaking - hope the bolts are all OK though.
Next Thursday if all goes to plan and using all Audi OEM parts and fluid.
Old 14th August 2013, 04:32 PM
Made a big difference to mine going that route - no complaints and I know when I next get it done any remaining cruddy oil should be removed too
Old 14th August 2013, 05:10 PM
Yes it resulted in a big improvement in my PF S8 - shortly before I sold it to IT, but there you go! Not sure how that is now....
Same place, same people doing it.
Old 23rd August 2013, 08:39 AM
All done and back with me, seems fine and even smoother, but I've only had a short drive.
Slightly cheaper than expected as they didn't need to replace the exhaust brackets (2@ £25 each + VAT!). Usually corroded to hell, the existing ones were actually in great condition and fine to reuse.
Still a bit of residual fluid to burn off, but there's virtually no smell now.
The owner of the garage obviously had to take it out for a few drives in the process and said it was "a really nice example and drives superbly; well worth keeping".
