hi i just got a a8 and the box has been fine had few other issues with electrics it had oil light abs light and no rev counter but went back in garage and they cleaned the connections up i take it and was perfect also when i took the key out the ignition come on not properly but did until opened the door then went straight of but that was sorted as well so that only left the washer fluid warning due to broken washer jet so i fixed that so it now had no warning lights so i thought great took the car for a run then all or a sudden it just started revving and no gears let the revs come down and it would cruise slowly, so got it home, the next morning i went out did the same but when it does it on the display where it says prnd234 ect was highlighted and doesnt tell you what gear its in, it then will slip but some times can start it up and doesnt then it does i can put it in triptronic but still doesn't tell you what gear you in all the time but can normally get it into 1st and drive it but soon as it goes up the gears it seems to start it hasn't had any problems before this
when i spoke to the garage i got it off they said there is a sensor that is realy bad behind the drivers side wheel but looks more like a abs but i don't know they said its to do with gearbox loom, it seems to be when it rained as well but might be a coincident any help would be great before car is sold as spares its a 1996 3.7 sport ![]() |
It's either:
(a) a dodgy/broken switch - relatively cheap, or; (b) a broken gearbox - not so cheap |
If it started doing it on a run then I would suspect the gearbox clutches to be slipping, its what happened with mine. If it happens when youre parked and selecting gears then more likely to be the switch, but either way run a vagcom scan and see what pops up. You need to make sure the garage that sold you it is still very much responsible for the outcome too I would say - good luck too. is it a 4 speed box or an early 5 speed?
hi its a 5 speed and it does it from cold but some times it doesnt do it thats whats wierd what would i get to sell it as it is?
Sounds like a mechanical gearbox fault with those symptoms - if it was electrical (the F125 switch which is probably what they're trying to suggest) then you wouldn't get any physical slipping of the gearbox. It would just go into limp mode (all DIS gear options lit up red) and still drive more or less fine, albeit only in 3rd gear or reverse!
How long ago did you buy it? Sounds like a very close inspection of the small print of sale of goods act may be required or a visit to CAB and/or trading standards may be required. I suspect your best hope is you return the car and get a partial refund back. The cost of a replacement gearbox, done properly, will be a significant proportion of the car's value. Depending on mileage of course. If you can't stomach the £1000-1500 cost of a repair, or get your money back, then breaking would probably be the most cost effective option and depends on spec and condition etc what the forum sponsors might offer you for it. Might be worth a visit to http://www.agc.uk.com/index.html if you're down that neck of the woods to confirm it's mechanical and the potential cost to repair. Hope you get it sorted Adrian
hi it was a private swap for my subaru so havent got a leg to stand on so ill proberly sell it as it is but what would i get get?
1996 car , 3.7, non quattro, similar ones sell for £600-1000 in good running order. With gearbox issue it's only good for breaking for spares so £200-500 depending on extras and condition of resealable parts that have demand.
hi its a sport so should break for half sensible but will see what happens
Non running non quattro 3.7 isn't gonna be worth much sadly....
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Looks at 148,000 miles on the clock of my own 3.7.....
