Old 22nd January 2009, 03:52 PM
Default Car stuck in 'park'
Just thought sharing my own experience might be useful.
I found on one occasion that my car ('97 A8 4.2 Quattro sport) didn't want to let me move the lever out of 'park', even though I had my big foot on the brake pedal. I switched off, then back on and away I went as normal.
A week or two later it did it again but this time it took me a minute or two of skiddling around, switching on and off etc before it would go into drive.
Went home and decided to fix it.
If this happens to you, get a friend to check if your brake lights are working properly. Mine were not, so plainly the car was not 'seeing' me putting my foot on the brake and therefore, correctly, prevented me taking it out of 'park'.
I dropped the trim below above the pedals-only took 10 mins and I've not done it before. Found a loose wire on the brake light switch.
Problem solved and no trouble since.
Old 22nd January 2009, 04:11 PM
Hi Simon, thats a new one for the collection as we've never seen it before, but it makes perfect sense...
Thanks for sharing
Old 23rd January 2009, 09:20 PM
Audi4.2
Guest
Posts: n/a
Very interesting to know that. will definately bear it in mind.
Wonder if the dealers would have found that!
Old 26th January 2009, 09:51 PM
Oli18's Avatar
Oli18 Oli18 is offline
Love it! Logical, quick and cheap...thanks for sharing this! :-)
-Oli
Old 30th January 2009, 10:10 AM
harpersimon
Guest
Posts: n/a
A good tell tale is you can hear the 'click' normally when you press the brake pedal as the lock disengages - Excellent find fella.
