Go Back   A8 Parts Forum > General Natter > House and Home DIY
House and Home DIY Everything at home. Building, Renovating, DIY, green initiatives, mowing the lawn. Anything goes
Old 18th May 2013, 07:55 PM
Default What is this?
I have installed this thing in my garage on opposite wall to entrance doors.
In my opinion, this is essential thing for all A8 owners who have ordinary size UK garage.
Any ideas about purpose of this device?
ID:	6043   Click image for larger version
ID:	6044   Click image for larger version
Old 18th May 2013, 08:40 PM
Does the red tube piece fire a Dalek like exterminate ray at any potential thief if they try to steal it?
Old 18th May 2013, 08:50 PM
I think you told me already so I'm excluded!
Are you recovered now Sergey? I'll call to catch up if you are
Old 18th May 2013, 08:56 PM
Cheers Neil. Tried to call you a couple of times, but number was unavailable.
Going from the yellow warning triangle on the device my guess would be that it is laser that marks dot or line so that you can line up car in the centre of garage.
Old 18th May 2013, 08:57 PM
Brian, this is not anti-theft / security thing.
Old 18th May 2013, 09:06 PM
lol
Old 18th May 2013, 09:08 PM
Correct Anairs! I didn't notice the triangle myself on those pictures to be honest.
Yes, this is industrial grade plane laser. It creates sharp plane of light which is aligned exactly in the middle of garage opening. Because standard garage doors in the UK are only 7" wide it is tricky (and dangerous) to park A8 in such garages.
Now driving into very tight garage opening is no problem at all. All I need to do is to align sharp line with climate control sun sensor, which is exactly in the middle of dashboard. laser is controlled remotely from button in a car. When I finish installation of new garage doors this laser will be switched on from doors operator automatically.
Old 18th May 2013, 09:21 PM
There are 3 components in this setup:
1. Boom, which is short throw projector mount manufactured by US company called Chief. Made in USA from aluminium
http://www.chiefmfg.com/Products/WM130AUS
http://accessories.euro.dell.com/sna...=baynoteSearch
2. Stainless steel floor mounted balustrade base element from UK company Elite Ballustrade Systems. Made in China from hi grade stainless steel.
http://www.elitebalustrade.com/floor...d-base-hd.html
3. 15mW 650nm industrial plane laser with two adjustable brackets and stainless steel rod in between. Special order. Made in Switzerland.
http://www.scitec.uk.com/lasers/idtlaser/pdf/idt5_e.pdf
Old 18th May 2013, 09:29 PM
I know it is a bit late for you but did you consider using green laser instead of red as they are less damaging to eyes if you happen to look straight into it. Or is availability an issue?
