Old 5th June 2013, 05:56 PM
rs32 rs32 is offline
Default adjusting boot alignment - D2 S8
Is there a set procedure for aligning the boot panel correctly rear quarter panels (even left/right height etc), and/or is it even possible to change the fine-tuning of bootlid alignment ?
The scenario is one side is slightly low and other slightly high. you can see this at the top, mostly where the bootlid reaches up towards the rear screen, but also on the lowest part of the bootlid where it meets the rear bumper. One side approx 3-4mm higher than the other.
Old 5th June 2013, 06:33 PM
Conquistador's Avatar
I have exactly the same problem so would be interested to know whether this is possible on a D3 also.
I pressed the boot release button in the car so a passenger could get something out the boot, the mechanical lid takes waaaay too long to fully open (you press the button, can switch the car off, unbuckle seat belt, open the door, get out, close the door and walk to back to the boot to find its still opening), and they obviously agreed with this because they lifted it while it was doing its thing opening, thus forcing the mechanics to run faster as usual. Now it sits slightly higher on the driver's side
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 6th June 2013, 03:19 PM
There's mine...
Passenger side which is fine...
Driver's side with the problem...
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 6th June 2013, 06:09 PM
christ the one I've seen is nowhere near that bad ....... maybe I just leave it
Old 6th June 2013, 07:15 PM
On the D3 isn't it an issue with the electric close boot? Can't recall if it's hinge or mechanism related but think it's quite common?
Old 6th June 2013, 10:24 PM
Motor can fail, but so can the hinge mechanism which can give that kind of problem.
Old 6th June 2013, 10:34 PM
I am no expert but I suspect this has caused the problem? hopefully someone who knows more about how they work will be along soon with more helpful suggestion, does it run on some sort of gearing? maybe lifting has caused one side to jump a few teeth, sorry this is all guess work, hope you get it fixed
Old 28th June 2015, 03:07 PM
johnny_quattro's Avatar
Default Mine needs attention too
Resurrecting an old thread, as the boot lid on my A8L D2 needs adjusting.
See attached pic that I snaffled from ELSAWIN...
Name:	Screenshot from 2015-06-28 15:56:10.png
