Old 23rd July 2013, 10:44 AM
Greg66 Greg66 is offline
Default Best roof rail/rack solution for D2 A8
I wonder if any of you clever chaps can help me.
I need something to carry a load on the roof of our A8. I have managed to buy a bike box which has defeated even the cavernous boot of the A8.
I've seen the OEM solution, and a Thule solution. Is there a better alternative? Any specific recommendations?
TIA.
Old 23rd July 2013, 11:32 AM
OEM and Thule are pretty much your lot for decent kits..
Old 23rd July 2013, 11:37 AM
gninnam gninnam is offline
Got most of mine from Fleabay - already had a few bits from the roof rack I had on the Ford Focus.
Good kit and fits well.
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 23rd July 2013, 11:41 AM
I've got Thule for mine, but check out Whispbar as well - they now list products for the A8 which they didn't when I bought the Thule ones.
They're very good for cars with integrated roof rails as they get the load as low as possible - I'm assuming their kits for saloons do similar. They accept Thule T track accessories like bike carriers and boxes
http://www.whispbar.co.uk/
Think Halfords sell them but worth shopping around
Old 23rd July 2013, 11:54 AM
Don't know a lot about aftermarket solutions but the genuine roof bars are specific to the 8 are nicely made, fit as you'd expect with a rubber shoe that cups the roofs contour and a tool for doing up the torx bolts to the 6-9nm.
I'm a picky, negitive git and i have to be honest i'm not sure you'll find a better alternative, cheaper maybe but the genuine ones are pretty danm good.
Just for reference with the 8’s door open have a look up on the underside of the opening and there are 2 little arrows pointing at each other, between these is where you fit your bars / rack.
Old 23rd July 2013, 01:28 PM
The genuine bars are made by Thule - main difference will be that the non-Audi branded alternative may fit something else with a different foot pack, whereas the Audi branded tend to be unique fit.
I have genuine Audi for the A6 and they're a very square profile bar but with the T section fittings for Thule accessories. They're quite noisy compared to later Aero or Wing bars made by Thule.
Modern bar designs tend to be a lot more aerodynamic in profile so less noisy and tend to favour carrying stuff with the T section fittings over old fashioned clamps - so depends what you want to carry as well.
A cheap set of Audi branded ones will be easiest to fit, for sure, but once setup properly the alternatives work fine.
Will find some pics of the Thule bars fitted to my S8
Old 23rd July 2013, 01:41 PM
Many thanks, all. Went for the Thule aero bars.
Old 23rd July 2013, 01:42 PM
Pics of Thule option fitted attached
They also come with the torque limiting screws to make sure you don't over tighten them.
I've used mine a couple of times and left no marks of any kind on the roof
ID:	6409   Click image for larger version
ID:	6410   Click image for larger version
ID:	6411   Click image for larger version
ID:	6412   Click image for larger version
ID:	6413   Click image for larger version
ID:	6414   Click image for larger version
ID:	6415   Click image for larger version
ID:	6416   Click image for larger version
Old 25th July 2013, 07:05 AM
I'm home this wk-end and i have to get the camera out for some other 8 photies so i'll take some of the bars i have. The ones i have don't have as much contact area on the roof, they sit on the raised part only on the outter edges of the roof.
Also yes they are quite square although i didn't really notice any more noise. But the box i picked up that is meant to be genuine had the fitting kit with it and that is Thule, u bolts come up thru the box and a twist type locking doodar that clamps the u bolts thread, i don't like it as there isn't much engagement on the thread and i'm assuming because the bars are quite fat.
I have gone with a new design called washers and nuts, i'm not wanting to blow my own trumpet but i can see it catching on.
Old 25th July 2013, 07:53 AM
Fitting tip for you, if you haven't done it already! Don't take too much notice about the measurements in the instructions - set them evenly both sides as a rough guide and then spend the time making sure the feet sit in the groove on the roof as snugly as they can. Do the clamps up a little each side at a time or you find the bar is pulled towards you. It will squeeze the chrome trim a little bit but it relaxes again when you take the bars off.
Excellent lateral thinking there Dezzy
