Old 17th August 2013, 08:36 AM
Default symphony to RNS -c d e retro fit ?
Im wandering if you can change a double din standard bose system for a RNS-C ect or at least any of them with a screen. ive had a verbal deal over the phone with a chap on a nice D2 on LPG but sadly it dose not have any screen and im wandering if any one can point me in the direction of a retro fit ect on this ?
hope to be back in an 8 soon
thank you
Old 17th August 2013, 09:03 AM
Didn't Ranj do this on one of his and document it on here?
If its got the double din fascia it shouldn't be much work to make it fit although I'd have to go for an E since the price difference isn't massive considering the extra functionality
Old 17th August 2013, 10:51 AM
yes i remember him doing it but i just cant find the thread when i searched for it ?
yes i agree for the sake of the extra 100 quid you could have RNS-E .. im just looking into it more than anything but i have to sell my little 1.9tdi leon first to fund towards the 8 .. im also selling my GSX600 aswell i decided its best to have an 8 rather than toys that only get used every so often rather than a nice day to day car on LPG
Old 17th August 2013, 07:22 PM
This may be the thread from Ranj -
http://forum.a8parts.co.uk/showthread.php?t=3680
Old 17th August 2013, 09:04 PM
Symphony sounds facelift, so if changing a facelift stereo for a facelift rns c/d/e then it's fairly straightforward as you don't all the climate and can bus issues which ranj and I tackled upgrading pf cars.
The symphony likely won't have a gala signal which you need for nav but you can tap that off the instrument cluster easy enough.....
Old 17th August 2013, 09:52 PM
Won't it want it for speed-related volume control and isn't it likely to be in the loom anyway even if that radio doesn't actually use it?
Even my 1998 vintage Ford Focus has a speed signal (GALA equivalent) in the standard radio loom. I happen to have upgraded to a Radio/Nav unit that uses it but not all do, and when I retrofitted Cruise Control recently that was the most convenient place to pick up the speed signal.
Though I do realise that the A8 is much less standard and far more custom in the wiring.
Old 17th August 2013, 10:00 PM
I think it took the speed off can bus rather than a hardwire from memory.....
And no, if it didn't need gala at the factory, it defo won't be there.
I did at least 2 upgrades from a double din fl stereo to nav plus on 2002 2.8's and they should have been plug and play but turned into more complicated affairs....
Old 26th August 2013, 03:20 PM
mannyo mannyo is offline
I did the double din symphony to RNS-D almost a year ago, it was a straight swap with some additional wiring needing to be done in order to get the canbus to the cluster, plus a TMC module. I got both from Ranj when he was selling them, and two wiring looms from ebay. Then it was a simple coding job. In my case at least, I did seem to have a gala signal since everything just worked perfectly and still does today.
This was the thread I created at the time.
http://forum.a8parts.co.uk/showthread.php?t=5332
Manny
Past
