Old 22nd August 2013, 12:57 PM
tadej's Avatar
tadej tadej is offline
Default Engine from FL to PF
Hello!
I have one question for you. Is it possible to install engine from S8 FL (360 HP) to my A8 PF (300 HP). Which parts should I change?
I have this part from S8 FL: engine, engine ECU, transsmision, transs ECU, rear diff....
Thanks
A day you didn't learn something new is a wasted day :!:
Old 23rd August 2013, 06:37 PM
Zdravo!
I think you have all the parts you need. I researched the part numbers when I was going to do a manual gearbox conversion, I think the front sub-frames are essentially the same.
Hopefully someone more knowledgeable will come along soon with better advice.
In the meantime make yourself an account on Vagcat
http://www.vagcat.com/
Its a free online parts catalogue, you can see part diagrams and compare part numbers from PF to FL, if part numbers are the same then you know its good to go.
Old 25th August 2013, 08:55 PM
Hi there,
Your big issues are going to be the Can bus and instrumentation. The FL uses can bus from the each throughout the instruments. FL is also a fly by wire throttle so a pedel cluster change may be needed.
Old 27th August 2013, 12:42 PM
tadej's Avatar
@Goran: thanks for link to vagcat From which country are you?
@Conan_the_Librarian: I know, that I will have a big problem with a motronic harness...and with CAN-BUS
Tell me something.... If I change just transsmission and rear diff, what I get?
More acceleration? Hire top speed?
Old 27th August 2013, 08:29 PM
Changing the transmission is pretty straight forward physically. Use a matching rear diff. You'll get better acceleration but lower mpg. I don't know if the TCUs on a FL need Canbus, can't think why they would.
Old 27th August 2013, 08:52 PM
Zdravo Tadej, I am from Beograd.
If you are changing just the gearbox you are better of changing to a manual, even more acceleration, less weight, gearbox will last longer.
