Go Back   A8 Parts Forum > General Natter > House and Home DIY
House and Home DIY Everything at home. Building, Renovating, DIY, green initiatives, mowing the lawn. Anything goes
Old 19th February 2013, 03:59 PM
sarg sarg is offline
For my sins, I used to work as an estate agent in South Kensington, I lost count of the number of times I'd be asked for either;
1. A flat no more than 5 minutes walk from tube station, but in a quiet area...
2. A flat with a garden, but not on the ground floor
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 20th August 2013, 08:18 AM
Finally have the floor covering done.
Thats got to be the best man cave I have ever seen, Missus would never see me if it was mine. Top job man.
Old 25th August 2013, 10:03 PM
47p2's Avatar
47p2 47p2 is offline
I tell SWMBO that I'm nipping out to the garage for half an hour and come in when its dark
Nite Blue 3.0L SE Quattro
Old 25th August 2013, 10:18 PM
I looked at this thread and noticed the garage is built from scratch with half brick thin wall. I thought it'd be a bit moist and cold. Any reason why you didn't go for warmer option with cavity walls, like a house?
I also noticed many vents in walls so perhaps proper garage should be cold... What's the theory here?
Old 25th August 2013, 10:39 PM
47p2's Avatar
It's only a garage so the walls don't need to be insulated, yes it's cold in the winter but it never gets below freezing so I am not too concerned
Old 25th August 2013, 11:40 PM
Thanks. My garage has cavity walls perimeter as it was built as part of the house (I have bedroom above garage on 1st floor) and I was thinking about adding heating to make garage warm inside -- hate putting lots of cloths on in winter while I work with car Last winter was -8C in Reading area. But I'm worried about corrosion damage to car as road salt will promote corrosion when it thaws, so I abandoned the idea. Perhaps it is better when car stays in cold during winter.
Old 26th August 2013, 05:14 AM
47p2's Avatar
I never put the car in the garage when it's wet, there's no air movement when the garage door is closed so it would take forever to dry off plus the damp would be attracted to all the other cars and the tools and everything else. If it's wet it sits outside until it dries off.
Old 26th August 2013, 09:17 AM
Surely your garage is air-conditioned.....
Old 26th August 2013, 09:22 AM
I'm thinking about aircon or dehumidifier ...
Old 26th August 2013, 09:26 AM
47p2's Avatar
Yes it has air-con but if I come in late and stick the car away for a few hours it doesn't get the chance to dry out
