Old 19th August 2013, 08:48 PM
Default Touch sensor on Door not working
The drivers door touch sensor is not working but everything else is.
Is it something that can be fixed or does it require the whole handle replacing.
Old 20th August 2013, 05:59 AM
Somerandomguy's Avatar
Ufortuanety, it will need a new handle. The sensor is embedded into the handle, so faults with either the touch sensor or button cant be fixed.
If you have VCDS the are some binary bits in the measuring blocks that you can use to test,
http://www.audi-portal.com/en/diagno...u_11294.html#1
Old 20th August 2013, 07:34 AM
Cheers for that I will have a look later on even just to learn VCDS a bit more
Old 25th August 2013, 09:50 PM
47p2's Avatar
47p2 47p2 is offline
My driver door doesn't lock, just hit the back door button...problem solved
Nite Blue 3.0L SE Quattro
Old 26th August 2013, 05:27 AM
I have resorted to doing that a couple if times too, as the lock button has started acting up too, when i get back I'll get it fixed as it's covered under warrenty.
