Old 17th July 2009, 01:30 PM
I did mine about 2 months ago now, just the seal and the oil. was prepared to change the housing but it didnt need it and its been fine since (famous last words lol)
Old 22nd July 2009, 01:54 PM
Waynester2 Waynester2 is offline
Mine was fine until I had the transmission fluid changed, then I got the distinctive smell that I think Ian described of the fluid dripping onto the exhaust.
Anyway cost me £260+vat at a local auto box specialist, for new gasket and a topup, so I'm feeling a bit ripped off now after seeing what you guys have paid. He did quote me £2500 + vat for reconditioning the box as well when/if it does finally pop.
Wayne
8 - 4.2 - 2002 - LWB
4 - 2.5 - 2004 - CVT - B6
Old 22nd July 2009, 02:29 PM
entwisi
Guest
Posts: n/a
I paid 2400 inc VAT for my complete rebuild.
Old 4th September 2009, 06:52 PM
Ben just changed my gearbox seal an topped up oil. All Audi OEM parts and labour..£80!!
Old 30th May 2010, 04:42 PM
Night Train's Avatar
My seal's been leaking for about 9 months now, Its on order at the main dealer who are going to charge £150 for the complete job.
They were going to do it when I had it serviced last week (£270) but had the wrong seal.
Other vehicles
Oh Yes....... The '98 PF S8!
Old 18th July 2012, 03:07 PM
Anybody know dimensions of original seal?
Old 20th July 2012, 03:55 PM
Well I bought a new seal from dealers @ £14.14, part number 018 409 399 B, ZF part number 0734 319 588. Its a directional double lip seal with dimensions 40x52x7mm. Will see if it fits without changing flange or housing or whatever is supposed to be changed at the same time. If not then will measure old seal and order viton seal by dimensions to replace old one.
Old 26th July 2012, 12:23 PM
quattroworld is your friend. There is a new re-designed output spline to take the new seal with a lip.
http://forums.quattroworld.com/a8/msgs/32544.phtml
someone fitted a new lip seal onto the old output spline shaft in mine, needless to say it started leaking again after less than 2 years.
Old 26th July 2012, 05:24 PM
At those prices for flange and covert I would rather replace seal every 2 years or use old style seal from third party supplier. After all original seal has lasted 15 years and 135k
Old 9th August 2012, 06:54 PM
Attacked the seal today looking to get it replaced before going to AITP and discovered that propshaft front CV joint gaitor is split. Dealers do not sell these separate, only complete propshafts at £1.2k. I don't fancy paying £100 for 15 years old second hand propshaft either so will go to local(ish) propshaft manufacturing/repair/modification company(30miles) and see if they gaitor in right size for sale.
Car is in bits and I do not know if I will put it together before AITP.
