Old 26th July 2009, 07:35 PM
Default Question to all members...
My DIS showed 0 Miles the other day, I never usually let it get this low. Anyway, I drove about 3 miles with it saying this and then put in some Tesco 99. Well you can see on the picture all I could get in...
Does the S8 not have a 90 litre tank? Does this mean theres about £13s worth of fuel in there when it says 0 Miles. Not that I'm going to risk it.. Just wanted to know if anyone else has the same thing or if my gauge/sensor is fecked!?
Old 26th July 2009, 07:38 PM
pretty normal... Does your 8 say E or R when the dis hits 0? R means resserve tank, and on the 8 it's about 2 gallons.
Old 26th July 2009, 09:12 PM
CliveH's Avatar
CliveH CliveH is offline
Default Yep
about 80 litres is all I've been able to squeeze in so far...
Old 26th July 2009, 09:34 PM
gninnam gninnam is offline
Managed to get over 20miles on '0' so must have quite a few litres in reserve - think the most I have managed to get in to mine was about 87litres.
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 27th July 2009, 11:04 AM
Reffro Reffro is offline
About the same here, I went 30miles past the '0' reading and managed to get about 87 litre in. Otherwise I never fit more that 80 litres on a single fill.
Old 27th July 2009, 11:16 AM
You guys have guts! How come you went so far over 0!? I suspect I will a little too now!
Old 16th August 2009, 09:20 PM
cheers lads! I took your info on board RE 20-30. Am currently conked out right outside a graveyard with 15 miles into zero, 3 miles from Shell (where I was going)!
Old 16th August 2009, 10:02 PM
Whoops
Once on 0 how did you drive - I drive very carefully once 0 appears
Andy.
Current cars:
BMW i4 M-Sport
Old 16th August 2009, 10:48 PM
Just put £98 of V Power in and shes as happy as larry now!
Was pootling around mate
Old 23rd August 2009, 05:46 PM
Generally, 80 ish litres is about what you would normally expect to get in when it reads around 0 miles left... There is usually a decent size reserve..
All UK cars have a 90 liter tank, but abroad some of the 2.8's had smaller ones. The long wheel base has a 92 liter tank due to those few extra inches..
We have found a few cars though where 0 means nothing! and, in rare cases where they conk out before 0.
Test your own car to see how far it will go, just make sure you have a can of fuel in the back ready
