Old 16th October 2013, 08:39 PM
Originally Posted by Mugzee View Post
Thats a great article, will be trying that out.
Old 16th October 2013, 08:46 PM
Indeed, I've printed it off and will have a preliminary look tomorrow.
Not sure about redlining an S8 in 2nd gear though, won't take long!
Old 16th October 2013, 08:51 PM
Haha, been done a few times, maybe I need to tow another 8 to redline in 2nd to slow it down a bit.
Old 16th October 2013, 09:18 PM
Mugzee Mugzee is offline
I know, the tech tips are quite interesting.
I think it's amazing how little information the driver is given by the vehicle itself really. As an example, you'd think manufacturers would at least fit things like oil pressure and temperature gauges from the factory as that is quite important, at least on higher-end models anyway (slightly off-topic, I know).
It's almost worth fitting a new MAF sensor every couple of years if it causes such a problem!
Old 16th October 2013, 09:40 PM
slow it down a bit.
Going a bit off topic I know, but that reminds me of picking up our youngest from Uni (Leeds) on our way back from Scotland (walking holiday) a few years back in the PF S8 when it was "at its peak".
We hadn't planned to do this and had a fair bit of our own stuff, but in the end we COMPLETELY filled the cabin as well as the boot and got all his stuff in - apart from the contents of 2 "bean bags" that we emptied into a large bin.
We ended up inching the electric windows up and slowly feeding ever-smaller items in (to him sitting in the back) until it was literally full to the roof. Both him and my wife had loads of stuff on their laps too.
I remember him asking - won't all this stuff slow us down rather on the way home!
Old 16th October 2013, 10:11 PM
Probably never even noticed it apart from not being able to see out the back window
Old 16th October 2013, 11:02 PM
Who bothers looking out the back window in an S8 on the M1?
Old 17th October 2013, 05:40 PM
Did a quick check today and the values were well within spec. Didn't do the redline test run though.
Old 17th October 2013, 06:06 PM
I haven't had time to do anything on the car yet other than buy bits for it. Had it a week today. Will be servicing the transmission on sat then have a play about with VCDS.
Do you think it's worth putting my other car in the Sales section? It is from the VAG group however not an Audi. Worth a try I suppose. . . .
Old 3rd November 2013, 12:08 PM
So a bit of an update really. . . .
Drained the transmission fluid yesterday and it was RED ATF!!! So annoyed. I have receipts from Audi for changing the fluid so unless it has been done since, they are the ones who put this fluid in. I still can't believe it.
I changed the filter, drain plug, relevant seals and gaskets, plus the all important Audi fluid. Carried out the fill procedure exactly. There were no metallic particles on the magnets, just the usual film of black deposits on the sump.
The thing that concerns me now is that when driving along at a steady low speed, then decelerate, the transmission seems to hunt to a lower gear and does so quite violently, shocking the drivetrain. Other than that, gear change is pretty smooth. This issue is a direct consequence of the fluid change as it didn't exist before.
My initial thoughts were that the fluid was low but I went through the fill process again and the level is fine. I'm now thinking that the mixing of the 2 fluids is causing an issue. . .
Any thoughts on this?
Currently driving - '99 Silver A8 D2 FL 4.2 QS
Currently for work - '08 Raven Blue T5 174
