Old 28th October 2013, 10:38 AM
Default Need info from RNS-D "hidden menu"
I'm now experimenting with RNS-E and wanted to confirm a number of ABS pulses per wheel rev on D2 FL cars.
I looked at ABS ring specs and it seems that D2s have 45 teeth/holes on ABS ring so that's 45 pulses per wheel rotation.
If someone with RNS-D can access hidden menu:
http://www.audi-sport.net/vb/satelli...n-options.html
and check this screen to confirm correct number of ABS pulses per wheel rotation for me please:
Many thanks!
Old 28th October 2013, 11:43 AM
HPsauce HPsauce is online now
I'll go and check mine shortly - chucking it down at present!
And the answer is: 2059mm and 45 pulses/rev (245/45R18 wheels/tyres). And I think that circumference is a bit low, should be nearer 2129mm.
So what will that get wrong, if anything. It will think the car is going about 3.3% faster/further than it actually is?
Old 28th October 2013, 01:03 PM
That'll only really get it wrong when the nav is using 'dead reckoning' and has no satellites (tunnels, been off for a bit, etc.). The rest of the time it'll use the GPS signal.
Old 28th October 2013, 04:45 PM
The actual screenshot is from another car, not D2, so tyre circumference is not correct. I run245/50R18 tyres and my tyre circumference is 2206 mm. All we need to confirm is number of ABS pulses per wheel rotation on D2 car.
Old 28th October 2013, 04:53 PM
45 on mine (D2 facelift S8) as noted above.
Cool. Thanks HP.
