Old 7th November 2013, 01:56 PM
If "some" of the information I have is correct then the 2nd digit is 2 for an A6, i.e. 02207.
Well it took that code of 02207 and subjectively I'd say it's noticeably better. For a start I can definitely heard bass in the boot now, though I still haven't refitted the plastic covers.
I have still changed the fader heavily to the rear, but the Bass is central. And even with all settings at nominal it definitely sounds better to me.
Old 7th November 2013, 02:06 PM
Pretty sure that was one if the issues with Brian's unit. not driving all the speakers properly and the coding sorted it out. It was ages ago, so I don't have a scan.
Old 7th November 2013, 02:31 PM
Can't remember what the coding was, but I think I had to code it to an A6 setting.. Though VCDS had the options listed.
OK, I didn't see anything useful, where was that, if you remember?
I only have VCDS-Lite (Registered though, I paid!) which doesn't have a full set of information.
Old 8th November 2013, 10:59 AM
Covers refitted, lovely job lying on my back in the boot in the pouring rain, no fun if you're as big and arthritic as me.
Tested by listening to Radio 1,2,3,4 and Bass is now really evident, especially from Ken Bruce! Clear bass notes from parcel shelf and inside the boot.
All the tone settings are at nominal except Fader which is 2 "blocks" in from extreme rear (3rd block from right).
Old 8th November 2013, 04:24 PM
I'm now really quite pleased, and rather sad I didn't sort this a while ago.
Been doing a little "stress testing" :
Mahler's Resurrection (2nd) Symphony, especially the finale
Aaaron Copland, Fanfare for the common man - lots of brass and tympani.
So, for anyone with a none-Bose RNS-D that's sounding a bit "thin", change the Radio soft coding from 00207 to 02207, and fader a fair way rearwards.
Old 8th November 2013, 07:46 PM
.....Been doing a little "stress testing" :
Bon choice. When testing out some speakers are a shop in Glasgow, i used Mahler's 2nd and Neil Young's "hey hey,my my (into the Black)". the first tests for dynamic response/vocals and full orchestra the latter just destroys speakers not up to it!
Old 8th November 2013, 09:20 PM
If you really want to test speakers you need to enlist Hotblack Desiato and Disaster Area.
(I believe they were in fact inspired by Pink Floyd and their Venice concert in particular: http://www.youtube.com/watch?v=gcxzaBSzlH0 )
NOT this Hotblack Desiato though...
Old 8th November 2013, 09:32 PM
Personally, I prefer to test with the live version of Iron Maiden's "The Clairvoyant", even the Bose in the D3 doesn't quite get it right but is absolutely stonking with most classical stuff (target audience I suppose).
Old 8th November 2013, 09:33 PM
Comfortably Numb is a pretty good test as well. (Or Run Like Hell which ended that Venice concert, apparently causing a fair bit of damage to various buildings!)
Old 9th November 2013, 10:18 AM
I tried other values for that 2nd digit, i.e. 01207 to 07207 and it made no discernible difference, so I'm sticking with 02207 for now.
A good test will be tomorrow, a long drive with SWMBO in the car; she has long complained about the difficulty of hearing speech clearly on the radio at "motorway speeds". This should be a good test.
