Old 8th January 2014, 08:26 AM
Default MOT Lottery Time
Dropped the car off this morning and hoping that with pads/discs and control arms all done in the last year that there will be a satisfactory result on this occasion.
Old 8th January 2014, 08:45 AM
Fingers x for you mate
I was lucky enough to be awarded another 12 months last month.
Old 8th January 2014, 11:38 AM
Sorry to hear that Dezzy. Where do you have to do your time? Did the car get through though?
Old 8th January 2014, 12:34 PM
DARTMOOR!
and yes she'll be ready for me when i get out
Old 9th January 2014, 08:05 AM
Ah well, A very intermittent problem that I had with the near side main xenon sometimes failing to work when first switched on (it always went on when I switched off and then on again) managed with spectacularly bad timing to manifest itself when the garage fired the car up for the MOT. (It was working on the drive to the garage!). So they had to replace the lamp there and then to avoid a re-test. The problem was arcing at the base of the lamp as the lamp contact was deteriorating/wobbly. However, cost of the lamp they got through their suppliers was £75!! - aaaargh - which is a teeny bit more than cost on ebay.
I guess I should have checked the problem out myself but it had only been a very occasional issue and its been too wet etc to do anything outside.
