Old 15th January 2014, 02:54 PM
What do you mean by 'unit'? The whole headlight? Or "the metal box about the size of a pack of cards attached to the side of the headlamp unit"?
If the latter, there must be a connection somewhere. I'll have a look on the spare headlight before I start!
Old 15th January 2014, 09:42 PM
The metal box It may have a connection at the box itself, or may be fed from connections inside the headlight unit.
Old 16th January 2014, 06:44 AM
There's no way that's coming off with the headlight in place, so it'll have to wait for the weekend!
Still don't really understand what the issue is as the replacement bulb (not new and a lower 'rating') is behaving much better (but not 100%). David's poor connection to the bulb problem makes me wonder if this isn't a similar issue.
Still, headlight out on Saturday.
Old 16th January 2014, 10:15 AM
Could be a tired component in the ballast if a lower rating bulb is happier.
Old 16th January 2014, 12:06 PM
Going to try to swap the ballast at the weekend, but mine don't look like this:
http://www.ebay.co.uk/itm/Audi-A8-D2...item2c6af945fd
more like this:
http://www.ebay.co.uk/itm/Audi-A3-S3...item43c41596b9
Am I looking at the wrong thing?
Old 16th January 2014, 12:42 PM
Could be part of the difference between Xenons and Bi Xenons...
Old 16th January 2014, 01:01 PM
Yes, could be. The A8 Parts ballast came off a 2000 A8. I think Bi-xenons were later IIRC?
Old 16th January 2014, 04:44 PM
SilverS8 SilverS8 is offline
more like this:
The BI-Xenons have a ballast on the outside and an ignitor inside the lamp. So both of the above
I replaced Everything with just a new ballast from ebay with new connections to the bulb socket mostly bc the cost of the oem's
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 17th January 2014, 06:49 AM
Getting more confused as this goes on!
Are these the connections? http://www.ebay.co.uk/itm/2808552182...84.m1497.l2649
And if this is the ballast: http://www.ebay.co.uk/itm/01-06-AUDI...item3f258d7a27
What's the plastic box here? http://www.ebay.co.uk/itm/Audi-A8-D2...item2c6af945fd
And do I need to replace all 3 components?
Old 17th January 2014, 11:18 PM
I used one of these
Ballast
And one of these
Connector
And finally one of these.(only need 1)
Power supply wire
The one that was blown on mine was UK driver side where the ballast is attached to the lamp, the new ballast wont fit onto the lamp so it needs to be placed somewhere behind the lamp. Wires was run true the hole where the old ballast used to sit and silicone was used to seal it.
if i'm not 100% sure but on UK passenger side i think the ballast is placed away from the lamp so that will make this easy and cheap fix easier.
Reason for going with this solution was:
-Unsure if the ballast or ignitor was broken
-To expensive to buy brand new and a used is over priced.
-It seemed that getting the ignitor out would be a pita of unknown dimensions.
Been working smooth for 1.5 years.
You can also use any 35w "slim" ballast but my experience is that they tend to stop working after a while
2000 Silver S8
