Old 18th February 2014, 06:11 PM
Thank you Del
Quick update, I missed another fault which I just saw.
See below.
Let me put the dinner on and I will do a fresh Auto-Scan so it's all up to date.
15min
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 20003061028100
Coding: FCFE5BDC2B7104
Shop #: WSC 02313 785 00200
VCID: 275D14099662EA26F59-8072
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 68
Mileage: 229465 km
Time Indication: 0
Date: 2013.11.06
Time: 14:26:09
Old 18th February 2014, 07:00 PM
I looked at auto scan in detail just now and this is how I fell right now
Previously I was jumping straight to the modules I was interested in and not paying attention to other modules. I will post auto scan again in the new thread to ask for advice because I need to get to the bottom of all the faults.
So, see attached Auto-Scan done 20min ago
It says that there is no signal/communication (19 - Can Gateway) with the phone/bluetooth module (R38) which I just installed and which is working other than people can't hear me and I can't use Voice Control anymore ???
Previously, 77 Telephone was unable to reach at all after failing/losing driver during the MMI update.
Old 18th February 2014, 07:14 PM
The phone module/CAN error is old, so could do with clearing down, and most of the others are nothing to really worry about, clear them and see if they come back.
Old 18th February 2014, 07:21 PM
Was going to say exactly the same, most faults are nuisance or not relevant, clear your dtc's then a quick run round the block and rescan posting your results.
No sleep for you mate, get to it chop chop, waiting for results...........
Old 18th February 2014, 07:23 PM
Hi PsYcHe, Del
This is the scan after clearing them all on Sunday. There is few I'm worried about, but not sure if I shall post the separately or in just one thread so every kind person can share some light on it.
I need to get to the bottom of that Mic issue. Looks like I've got 3 mics because of the factory fitted voice control and phone, and all of them show value 0 in advanced measuring blocks.
GO TO Page 2 of this thread where I posted more info earlier on during the day
Thank you once again guys
Old 18th February 2014, 07:26 PM
Look at this
Scan Before clearing all DTCs and After (Sunday 16/02/2014)
New Telephone module and Airbag wasn't fitted/fixed yet at that point
Old 18th February 2014, 07:39 PM
I'm going to do AS again, will clear the DTCs, will take it for a spin around car park and do AS again.
I'll be back in 15-20min
Old 18th February 2014, 08:02 PM
Done, see attached
So, MIC still not working same as Voice Control
Old 18th February 2014, 08:11 PM
Doesn't read so bad now does it, ok what pr code do you have for your telephone in the car? mines 9zf
Old 18th February 2014, 08:18 PM
Interestingly I looked at my coding for (77) and its different to yours mine is 0010900 which decodes as follows
00?0xx0: MMI System
1 = MMI/Sound System High
00x0?x0: Installation List
9 = Vehicle with MOST-Databus
00x0x?0: Voice Control Language
0 = Voice Control OFF
Now Voice control off has me asking what does that refer too as my car has the speech crap where you talk to it likr call so and so or navigation etc etc and it all works with that coding.
Either its a typo on ross tech or it is referring to something else.
