Old 26th February 2014, 06:31 AM
Mugzee Mugzee is offline
Originally Posted by yrk2.7t View Post
Good catch there is not
You have to loosen the bolts on the one side where the diff is located and then without letting the front diff fall out pop the bottom of the cover out so the fluid can drain out.
Or I suppose you could also try to suction it out of the fill plug.
I like method #1
I guess the potential for leaks from disturbing the o-ring is quite high? Is it worth the risk?
Currently driving - '99 Silver A8 D2 FL 4.2 QS
Currently for work - '08 Raven Blue T5 174
Old 2nd March 2014, 02:02 PM
I did this last year. Try to suck most of it out through filler plug. Removing the cover requires the removal of quite a few other things to access all the bolts and i dropped the sub-frame i think to get the lower ones - cant remember which ones. What is looks like with Final Drive removed:
http://forum.a8parts.co.uk/showthread.php?t=6575
Old 2nd March 2014, 02:07 PM
I wouldn't bust your balls over it tbh, just remove what you can and top up, it will be fine. Very little contamination in there and the magnets do there job to attract any 'grindings'.
