Old 23rd March 2014, 02:51 PM
SilverS8 SilverS8 is offline
Default Todays faultcodes
Had a little scan due to some other unknown problems when these showed up.
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to Plus - Intermittent
01176 - Key
07-10 - Signal too Low - Intermittent
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
00771; must have appeared after i changed the fuel pump, but fuel gauge and all seems to be working perfect.
01176; Does this mean the battery in the keyfob is going dead?
00668; Any idea?
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Something to do with the 01176 code above?
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
44-10 - Short Circuit - Intermittent
00862; had to check Navigation after the readout and yes, my car seems to be in the middle of the north sea... Any easy fix or aftermarked gps module availible like for the RNS-D?
Brgds Jan
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 23rd March 2014, 03:00 PM
If the aerial has failed, e.g. due to corrosion (as one of mine did a few years back), you can probably get another from A8parts.
I bought an aftermarket one and spliced it in with some creative wiring. Mounted it at the very base of the back window (outside) and ran the cable via the hinge mechanism into the boot lid where I spliced it in to the existing cable.
There's some information on here about it somewhere, but it was a few years ago! The OEM unit uses an unusual connector so I had to do a bit of soldering.
