Old 5th April 2014, 09:07 PM
gninnam gninnam is offline
Did they code the new battery in to the car?
Not sure what issues it would cause not coding it.
New battery was coded so not the issue
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 5th April 2014, 09:08 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I expecting it to moan and refuse to do anything cause the battery is not coded.
[center]
06 3.0TDI Quattro:
Options:
Old 5th April 2014, 09:16 PM
Battery was coded and key pliper works the doors/boot and starts the car but the keyless part does nothing
Andy.
Current cars:
BMW i4 M-Sport
Old 5th April 2014, 09:23 PM
Battery coding is purely for battery management system which will adopt the charge accordingly to battery age/use over the years, or something like that
Old 8th April 2014, 08:57 PM
Just try disconnecting the battery again and reconnect cleanly without arcing.
Old 8th April 2014, 09:10 PM
Mmmm when I had all my electrics out of the boot I had the same issue as you report. I don't know what was in there that would cause that but check the fuses above the battery that feed the fuses on the passenger side in the cubby hole in the boot, also check the fuses on the little fuse board in the cubby too.
Old 21st April 2014, 07:07 PM
Thanks to M-A8 and sending me the cable I have scanned for codes and this is what I have got:
The above is from the KESSY - anything else required (can't find any documentation on using the software.......)
Mean anything to anyone?
Andy.
Current cars:
BMW i4 M-Sport
Old 25th April 2014, 08:14 AM
No one can help
Andy.
Current cars:
BMW i4 M-Sport
Old 25th April 2014, 09:13 AM
No one can help
Can't view the images at work, will look at it later.
Would this manual help??
http://www.orebrobildiagnos.se/OBD2/...SER_MANUAL.pdf
Old 25th April 2014, 09:51 AM
Cheers - the document is not for the same version - some of the screenshots don't match what I see in my version - but thanks
Andy.
Current cars:
BMW i4 M-Sport
