Old 11th April 2014, 08:39 PM
still doesnt explain the 3000 miles where everything is OK unfortunately
Old 11th April 2014, 11:35 PM
I actually drove roughly 3000 miles after I changed front brakes before the judder developed!
Old 12th April 2014, 12:59 AM
Sergey's point is very valid. We all expect the source to be the front. But his was obviously not.
The 3000miles issue may be explainable by the fact that when new, the tolerances are such that the vibration/judder cannot occur but, after a bit of wear, the pads (or whatever) have sufficient movement/slack to start the judder. Maybe.
Old 12th April 2014, 11:01 AM
Or it could be that it takes around 3000 miles for uneven pad transfer to build up?
due to some component not sitting/moving correctly.
Old 12th April 2014, 03:52 PM
Jim, there are some excellent suggestions here, but its the fact that things seem OK for 3000 miles that seems strange maybe David's suggestion of a visit to a Procut expert might be your next move, looks like there is one in Paisley.
Can you send me a link Brian? I can't find it
Old 12th April 2014, 05:44 PM
http://www.skimmydiscs.co.uk/find-yo...ervice-centre/
Old 12th April 2014, 08:37 PM
Owen Ferry knows his stuff.. used him when I first got my d2, and he did some work on the xc90 as well.. nice guy.
Old 14th April 2014, 10:00 AM
Thanks Guys, I'll drop by later today I think and have a chat
Old 15th April 2014, 08:48 AM
Spoke to Owen yesterday and booked the car in for next Tuesday. He has all sorts of gadgets to test brakes, skim discs in situ and check disc temperatures. I feel that he'll look into the cause of the problem, rather than just keep replacing parts.
Thanks for the pointing me in this direction folks!
Old 15th April 2014, 03:54 PM
Bandycoot Bandycoot is offline
This is exactly the same problem I'm getting on my FL S8. Juddering after about 3000 miles. I've been using EBC Turbo grooved discs and yellowstuff pads but its always the same: Judder, skim, 3000 mile later more judder, skim. It's now getting rather monotonous. I've rebuilt the calipers, which was easier than I thought it would be, but no difference. I've changed pads, discs still no difference. Sadly, in Dubai we don't have anything as sophisticated as Procut but there are plenty of Bodge-It, Fleece-'em and Scarper machine shops that will make matters worse.
I'm convinced the problem is with the front brakes as when moving quite slowly and applying the handbrake there is no judder at all.
One avenue I am pursuing is regarding the front wheel bearings. I had one changed about three years ago and this judder has only occurred since then. The wheel bearing itself comes in a housing that once the hub has been pressed in it is then bolted to the steering knuckle. If this housing has been bolted into the knuckle slightly out of line then this would create a slight misalignment between the disc and the calipers/pads. This could, I think, cause uneven wear which could cause judder. What do you guys think?
2001 D2 S8. Volcano black. KW Variant 1 coilovers. EBC Turbo grooved discs with Yellow Stuff pads. 19 inch R8 replica wheels with 255/35/19 Michelin Super Sport. In the UK, 1990 Audi 90 2.3 20v Quattro with just 65,000 on the clock and in mint condition.
