Old 9th May 2014, 07:47 AM
Default Flickering handbrake light
When my car was serviced they told me that the handbrake warning light wasn't working. Not an MOT issue and everything was working fine so just a report.
Investigating further I found that it actually flickers on a bit while moving the handbrake lever, but is definitely off at other times, so I suspect a loose or failing microswitch.
Does anyone know where the switch is and how easy it is to swap?
Old 9th May 2014, 09:11 PM
No-one know?
A bit of rummaging online suggests that almost all VAG cars of that era use the exact same switch, 1J0947561, so would the D2 be different?
Old 9th May 2014, 09:23 PM
D2 is different: 4D0 947 563
But your switch may be OK. Don't buy until you diagnose.
Old 9th May 2014, 09:36 PM
Thanks for that, and yes I'd want to investigate first as it may be loose or have poor wiring.
Any idea where it is and how to get at it?
Old 9th May 2014, 10:02 PM
should be under the handbrake lever, but I have no idea how to get there.
Old 9th May 2014, 10:13 PM
Nor me. Centre console out job?
Old 10th May 2014, 08:40 AM
johnny_quattro's Avatar
I've just had a look on ElsaWin and it looks quite a detailed job to someone of my limited ability ;-)
Item 10 is listed as the handbrake switch.
ID:	8013   Click image for larger version
ID:	8014   Click image for larger version
ID:	8015   Click image for larger version
Old 10th May 2014, 08:48 AM
Thanks for that, definitely looks like it's all hidden under the centre console.
I think I'll just live with it.
Old 10th May 2014, 02:38 PM
Well I've found the cause.
Decided to have a look through the gap below the handbrake handle and see what was visible, so I lifted the armrests right up and pulled the handbrake on hard to maximise the gap.
First thing that happened was that the trim on top of the handle came loose. The clip at the front end had lost a component in the past and been bodged with duct tape!
Then I noticed a black hard plastic "stop" (about 30mm by 15mm) below the handle. This clearly was missing whatever the top cushioning element was supposed to be; it appeared to have been peeled off.
Looking into the gap I could see a plunger and some wiring, so I thought I'd get a long screwdriver and push the plunger down firmly a few times in case it was just dirty contacts.
As soon as I touched it the wiring plug fell off. Presumably someone had been in there doing some work and not pushed it back on properly.
I can't see the contacts the plug fits on to, and manipulating it through a small hole will be tricky, but if anyone has a diagram I can study I'll think about giving it a go.
I've tried searching for an image of the switch that might help, but not found one yet.
Old 10th May 2014, 02:46 PM
B@fink B@fink is offline
Messrs Bodgit and Scarper from the sounds of it.............
