Old 29th May 2014, 12:07 PM
I got the coolant one fits.
But the oil one don't fit the 3.0 TDI. I got to modify mine.
Black brake caps from Pug fits as well.
That's if you want to make it all subtle.
Sweet
Old 29th May 2014, 07:14 PM
Added a little bling today
Looks like I need to get busy tidying up the engine again as its getting grubby, Marcin would never aprove.
Del, your bay looks way much better than mine after recent events and a visit in the bodyshop
It's time to get busy, again
I approve
And I like the new caps boys, something I will look into for sure.
Del, wheels..and the car...look, hmmm, what's the word?...is there a word to describe such a amazing looking S8???
Absolutely mind blowing, very very very beautiful
Old 29th May 2014, 07:29 PM
I approve
Oh I do look forward to a picture heavy thread Marcin of current state through to show condition as I won't be at the meet to see it in person.
Old 25th March 2016, 04:16 PM
Default Tackled the snakes wedding today.
The media rack has been annoying me for some time and was in need of a tidy up after previous owner had a after market dvd changer fitted and wired in along with monitors in the head rests and my retrofit of the reverse camera.
My routing of wires wasn't the best first time round and I spent quite some time today taking the rack in and out whilst rerouting harness and cloth taping them in.
I also had the mystery item in there that i wanted to remove if it wasn't doing anything too.
I assume the mystery item was a tracker as it wasn't connected to anything other than power and appears to have an antenna or two.
Its out and gone now happy days.
The rear screen installers did a good job but then cut corners on the Aux input wires.
I found today whilst fitting an output harness to the tuner that the input they had wired in from the DVD changer was tinned wires pushed into the plug in the hope that they connected with the pins in the tv tuner
Surprisingly they never failed but thats been binned now.
So I now have torn out all the unnecessary wiring and fitted the Output from the TV tuner to feed the Rear screen inputs and taped and tidied it up to my satisfaction.
People that are looking for ways of getting power in the boot should perhaps consider what the installers had previously done which works quite well and thats add a separate fuse panel with relay like in the pictures.
It allows one to add switched live and permanent live feeds to whatever you need.
The relay is switched by the black/yellow wire from the parking module pin 1 IIRC, and fed from the supply on the other fuse box next too it.
All back and and working first time so happy days.
ID:	12838   Click image for larger version
ID:	12839   Click image for larger version
ID:	12840   Click image for larger version
ID:	12841   Click image for larger version
ID:	12842   Click image for larger version
ID:	12843   Click image for larger version
ID:	12844   Click image for larger version
ID:	12845   Click image for larger version
ID:	12846   Click image for larger version
Old 25th March 2016, 06:06 PM
Derek29 Derek29 is offline
How did you do that?
Old 25th March 2016, 07:32 PM
Del,
That will be "Connector A Pin 1", Black Yellow is correct.
Wish I had thought of that way back, but now I know how to do it.
All I need is a fuse strip and a relay.
Old 25th March 2016, 09:54 PM
I have the hybrid TV module that has two Aux inputs and an Aux out
The pin numbers are like in this link
The cable I used for the Aux output to the rear monitors was one of these if you also want to use your inputs you will need 1 extra for each input.
Old 25th March 2016, 10:00 PM
Del,
Spot on Ray, A1 is terminal 15 in DIN speak or ignition live to everyone else
Old 26th March 2016, 03:10 PM
Very tidy
Old 26th March 2016, 03:42 PM
Just found one of these on fleebay:-
http://www.ebay.co.uk/itm/301771732740?_trksid=p2060353.m1438.l2648&ssPageNa me=STRK%3AMEBIDX%3AIT
It is a relay with a fuse in line with the Normally open contacts.
I only plan on one extra bit of kit, a DVD player, so this will suffice.
Then I spotted this at the same shop:-
http://www.ebay.co.uk/itm/311213044119?_trksid=p2060353.m1438.l2648&ssPageNa me=STRK%3AMEBIDX%3AIT
This is a remote with a relay. At the price worth buying for a play. Might be able to fire the Aux heater remotely from indoors
