Old 30th May 2014, 11:41 PM
kevinas88's Avatar
kevinas88 kevinas88 is offline
Default Audi A8 Tail-lights as DRL
Hi,
I am new at this, cause I own Audi A8 only more then a month. Today, I received diagnostic cable from Ross-Tech. So I went test it with my car. I added battery level already on my MMI screen, also I added Oil level, but at the minute it's in dark grey, I did little research so I find out that needs activated in "Long Coding also", but I found another feature which I would like add for my car, it's how to do Tail-lights as DRL on Germans web site where I found it's step by step guide for Audi A5, so I am wondering, if I could make it same on my Audi A8, cause I own latest facelift on D3 platform which has awesome LED tail-lights so I would like activate same way as DRL, that always be ON, hopefully I will find some one who has more experience then me with changing stuff on Long coding.
Here is a web page where I found info for Audi A5 page no.6:
http://www.motor-talk.de/forum/aktio...hmentId=680908
Old 1st June 2014, 09:52 PM
Isnt this the "SAE rear lights" option in comfort systems coding section?
http://wiki.ross-tech.com/wiki/index..._System#Coding
+0002048 = SAE Rear Lights (PR-A8U)
Old 2nd June 2014, 07:16 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
What does the DRL rear lights look like?
Side lights?
[center]
06 3.0TDI Quattro:
Options:
Old 2nd June 2014, 11:02 AM
kevinas88's Avatar
Side lights?
Tail lights switch on all the time.. Cause I have on my A8 DRL (day running lights) 5 leds in head light. You have to leave light switch on OFF and activate DRL on MMI so it's lights up twice brighter as usual, but on that mode tail-ligts is off.. I would like to code them to DRL option, when I am activated DRL on MMI that tail-lights light up as well..
Old 2nd June 2014, 03:59 PM
Why not just turn your lights on?
Old 2nd June 2014, 09:59 PM
kevinas88's Avatar
Because DRL are twice brighter as on switch on mode and looks much better on day light when DRL are activated. I will try make some pictures tomorrow.
Old 10th June 2014, 10:48 PM
kevinas88's Avatar
As you can see on this picture DRL is activated.
Old 10th June 2014, 10:52 PM
kevinas88's Avatar
Smile
On this one lights are switch on, so if you compare those two pictures, you will see that DRL lights are twice as brighter them just normal switch on. But tail-lights stays off on DRL, that's why I would like to re-coded as someone did on A5.
Old 11th June 2014, 04:41 AM
Oli18's Avatar
Oli18 Oli18 is offline
Marcin is also trying to achieve this as am I to no avail just yet. I don't think I've come across someone having done this successfully just yet ...
Oli
Audi A8/S8 D2 Flickr Group
