Old 18th June 2014, 03:35 PM
fletberbill fletberbill is offline
Default Slight hesitation at low revs
Hi all I have a 99 plate 4.2 Quattro sport.
It seems to hesitate under 2500 rpm it goes very well above 3000rpm.
Any suggestions on anything to look at?
Thanks in advance.
Old 18th June 2014, 03:49 PM
Have a look at some of the threads in this section - there are a few discussing similar/same issues. I know that HP sauce (a member) has a thread about a mile long on this!
Old 18th June 2014, 05:23 PM
A mile long and going nowhere..........
(The last suggestion was that it was related to torque converter slip vs lockup which is "locked" in tiptronic mode so potentially testable. Nothing conclusive as yet, but my symptoms, which have been absent recently, may be different anyway).
Old 18th June 2014, 05:41 PM
I have read your thread a couple of times
Mine is hesitant in all gears, in auto or tip until you start getting the revs up, over 3000rpm there is no problems at all.
It can sometimes be worse when it's cold for the first few minutes.
Old 18th June 2014, 05:55 PM
Broken intake manifold switch over links?
Old 18th June 2014, 06:00 PM
Or faulty coolant temp sensor - I had that and it caused all sorts of oddness, but especially difficult starting.
Old 18th June 2014, 06:02 PM
No problems with starting and it idles fine.
Old 18th June 2014, 07:23 PM
That gets my vote. The 3-stage manifold flaps operate/change over at 3360rpm (and 5200rpm).
Old 18th June 2014, 07:25 PM
Sounds expensive? is there an easy way to check?
Old 18th June 2014, 07:40 PM
Very easy to check, think it's in engine stickies. Just pop the engine cover off (4 turnscrews) and look at the links. 1 minute initially.
If not broken check they actuate when the engine starts.
See: https://store-lyr7tp5r.mybigcommerce...e_Link_DIY.pdf
