Old 28th July 2014, 08:55 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I'm not really sure.
Its raised, not pitted.
The valve thing at the top of the piston is not sitting flat either. Going by his videos its a bad thing?
A friend said he's happy to have a look at it and see if they can make it smooth again.
I'll see what happens after christmas.
I'll get VCDS on it tonight and check pressures.
It definitely seems quicker on the lift.
[center]
06 3.0TDI Quattro:
Options:
Old 28th July 2014, 10:19 AM
it almost looks like someone has installed tape in the bore to try and seal it better
I like your valeting stool thingy Scott where did you get it?
Old 28th July 2014, 10:54 AM
ScottD3's Avatar
Unless it sucked something and it caused it. I got no idea.
My mother in law bought it for me. Found it on ebay but can't find it now.
All the ones on there don't have the 3 draws.
[center]
06 3.0TDI Quattro:
Options:
Old 28th July 2014, 11:00 AM
I would invest in one of these if your going to have a go at it again
http://www.bodyshop-tools-supplies.c..._JIaAiao8P8HAQ
Old 28th July 2014, 11:28 AM
ScottD3's Avatar
That could be handy.
Be cheaper than buying a new pump or sending it off.
Thanks.
[center]
06 3.0TDI Quattro:
Options:
Old 28th July 2014, 11:43 AM
Somerandomguy's Avatar
Wired my dash cam up properly at least.
I used this little port off the heads up controls.
All in and working.
I dont suppose you have the part number for the plug and repair wires that you used? I want to fit the auto lights so need to plug into the same socket as you used..
Thanks
Old 28th July 2014, 11:54 AM
ScottD3's Avatar
Auto Lights, head lights?
or the other kind?
I'm not sure what the other kind are.
Plug
8k0973754
Cable
000979009E
[center]
06 3.0TDI Quattro:
Options:
Old 28th July 2014, 12:34 PM
Brilliant- I spent hours last night trying to find the part number it ETKA,so have now ordered it.
Its the auto headlights that i am retrofitting(or trying to)- i have the sensor and light switch ready to go, just need to make the wiring loom to link the sensor to the CAN and power on that little socket.
Old 28th July 2014, 12:48 PM
ScottD3's Avatar
Go carefull with that plug.
I got auto lights and that plug is not used.
Its used for something to do with auto lights but i'm not sure what.
I guess if its power and can, that's all you need and it all goes to the same units?
[center]
06 3.0TDI Quattro:
Options:
Old 31st July 2014, 11:19 AM
ScottD3's Avatar
Found something cool out today.
If I hold both front window switch up/down all windows and roof with open/close.
No need for the ignition to be on or anything.
[center]
06 3.0TDI Quattro:
Options:
