Old 2nd August 2014, 10:26 AM
Charlie Charlie is offline
Default D3 Battery Recommendation
My D3 needs a new battery - sitting at 14.5v while idling, but drops well below 12v when not running making it requiring a jump start most days, embarrassing! So in my mind, the battery is on the way out.
Mine seems to have a 'Normal' battery - have any of you guys upgraded to one of these AGM batteries? Worth the upgrade?
Does anyone have a recommendation for a well priced battery retailer?
The car is a 2006 Build A8 4.2 TDI Quattro Sport.
Old 2nd August 2014, 11:28 AM
sarg sarg is offline
Bosch S5
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 2nd August 2014, 12:34 PM
When you get your new battery, don't let it sit below 12.3V~12.4V (no load voltage) for weeks. It will sulphate and reduce the effective capacity of the battery. Lead acid batteries don't like to be at below 50% state of charge.
My only 3 year old 110Ah Varta battery is struggling because the previous owner must have done just that, so it will charge 12.7V, but drops in minutes to 12.4, and after 4-5 days of no use goes down to 12.2. And I only have a parasitic drain of 0.2A ~0.3A
http://batteryuniversity.com/learn/a..._to_prevent_it
http://batteryuniversity.com/learn/a...tate_of_charge
http://www.batterystuff.com/kb/artic...ry-basics.html
Is a D3 solar roof wired to trickle charge the battery? if not that would be a excellent mod.
Old 2nd August 2014, 04:57 PM
I was looking at the Bosch S5 - some sites say type 019 others type 020 - I'm pretty sure the larger 020 will fit the D3 so I think I'll go with that.
Eurocarparts are doing it for under £115 (via eBay but collect in store) which is not too bad.
Old 3rd August 2014, 03:21 PM
Try the discount code UKPASSAT25, it used to work...
