Old 2nd November 2014, 12:25 PM
As above, USER option is available only in cars with finger print recognition
On my 06 2G MMI ver.5570 I have Audi parking system and interior lighting
3D maps very available from early years, but this option is available only in later versions of MMI
To switch to 3D press NAV and then SETUP button on the MMI console
You will see option of MAP TYPE
MMI 5570 (CAR and then SYSTEMS)
ID:	9427   Click image for larger version
ID:	9428   Click image for larger version
ID:	9429   Click image for larger version
Old 3rd November 2014, 06:45 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
It would appear I have 21.2.0.
Time for a update I think.
[center]
06 3.0TDI Quattro:
Options:
Old 3rd November 2014, 03:43 PM
madcjd madcjd is offline
Originally Posted by mannyo View Post
Chris
I assume the parking sensors are working ok.
If the car does not have keyless ignition then there is no user menu, instead it uses a combination of the keys and the memory buttons in the fold out door storage.
There is a hidden menu where you can add and remove options from the car menu, however it is possible to break the MMI altogether if you select the wrong thing. From the car menu, press and hold car and setup at the same time and a menu should appear.
http://car-tutorials.blogspot.co.uk/...reen-menu.html
Do not select anything in the menu to do with bootloader, it will end in tears.
Cheers Manny.
Yes - the car has fingerprint recognition and the parking sensors do work.
I'll give that hidden menu fix a try .....sometime soon.
Re the update discs for SW version 5570, someone has indicated the 3 discs are cheap as chips from Audi (makes a change)!
He reckoned less than a tenner?
Previous cars
A8 D4 4.2tdi lwb (2011)
T5 Caravelle exec 2.5 (2006)
A8 D3 4.2 quattro (2003)
A6 4.2 quattro avant (1999)
A6 2.8 quattro (1998)
Audi Coupe 2.6E (1993)
Carlton 3.0 GSI
Old 3rd November 2014, 04:01 PM
If you can get a dealer to sell them to you, theyre cheap.. some dealers are funny about it.
Old 3rd November 2014, 04:48 PM
Yep, the dealer wouldn't sell them to me. I had to get them from TPS. Ironically the dealer would also have got them from TPS!
Both items are update CD's. Cheap as chips!
Matt
Old 8th November 2014, 08:03 PM
Thanks for the info!
I'll get on the case soon.
Don't understand why a dealer would be reluctant to sell the discs?
Previous cars
Carlton 3.0 GSI
Old 9th November 2014, 11:22 AM
Think about it this way.
They dont make any money from the sales of discs, and dealer is only after your money. So, not everyone is same and where one person will just turn around and continue to look for discs, the other guy may just can't be bothered or not be informed well about where else to get them from and may just go with dealer doing the update for a lot of money - dealer is happy at this point
Old 9th November 2014, 05:09 PM
It could also be a retail vs. trade thing.
Don't forget the EU block exemption rules, Audi can't withhold these discs from other traders.
Old 9th November 2014, 08:15 PM
Hi Matty.
Do you have to be 'trade' to buy from TPS?
I've just looked on their website and seen that Slough is my closest dealer. However, the website implies it's for trade only?
Previous cars
Carlton 3.0 GSI
Old 10th November 2014, 12:41 PM
Originally Posted by madcjd View Post
Hi Matty.
I'm not trade and I've used TPS a number of times. Usually the parts aren't in stock so they order it and then pay on the day they arrive to their shop / trade counter.
Matt
