PICTURE GUIDE of cluster removal added below
![]() Cost: - as low as £195 if buying a used cluster from ebay for £100 and knowing right people to do CP removal and mileage correction - to min £260 if buying used cluster from ebay and letting Audi to do the CP and mileage, BUT you will have to present some sort of ''legit'' in their eyes a proof of purchase which Audi seems to require in order to do it, and if you remove the trim for them. If you dont remove the trim they want £320 for it inc. CP and mileage, but prices do vary and my local Bexley Audi is know for being absolutely dog s**t, so in this case total would be around £420 - or as high as around £800 if you want to buy new cluster from Audi and have it all set by Audi My cost was £205: - £110 for ACC petrol cluster - £60 CP removal - £35 mileage correction Tomorrow I will post a full guide of how to swap clusters for those guys who don't know how to do it or are afraid of it, don't, it is a simple swap and it takes around 10-15min. I managed to do two cars in under 25min. So, after talking to my ex-Audi MTs they strongly recommend to get the correct cluster and don't bother with swapping the RPM's or SPEEDO discs from Diesel to Petrol or vice versa or KPH to MPH and vice versa. From their experience on other Audi's the needles after removing and resitting will shake and give not accurate readings. Plus, it's not tested if petrol cluster will work on diesel car after CP removal and coding. What I have tested is if you for example have a patrol car with small display and spare cluster with wide display from another petrol car, that you CAN'T avoid CP removal and mileage correction by swapping the LCDs. I've tried, swapping LCDs with it's individual power supply PCB, but no luck. Display will be showing funny lines aven after playing with all the coding and adaptation options. Below you see a petrol wide dis and petrol small dis clusters during the swap process. Plus few extra photos if you are interested to know what's inside. Differences. So far I haven't found a single function being better on small dis than on a wide dis cluster ![]() Benefits. Main one is the look, absolutely amazing transformation and as I like to say more modern look. Full track names (if you record CD text of course ![]() Full street and road names When pressing MODE button on the steering wheel to get to the Telephone functions, MPGs and outside temp still displayed at the bottom of the screen, plus you will see signal bars at the top of the screen, not only on the main MMI screen When fuel light or and screenwash lights comes on they wont take over the top part of your screen anymore, they will display on the sides.top corners so you can still benefit from full track names, temp etc. Better Nav mode, in my opinion. When displaying any of the Trip Computer functions it will actually says at the top Trip Computer 1 or 2 Quick Note If you can buy or have no option then buying a Cluster with ACC and you have only CC installed, not ACC, then you can still go ahead with swapping a CC cluster to one with ACC LEDs around the speedo and additional ACC light on the speedo disc (both functions are greyed out and not visible when ACC is not active/installed) Your CC will still work, but the Green CC Light (speedo symbol) will no longer come on even if it is still present on ACC cluster. Also immediately after installing new ACC cluster and removing CP and coding it there will be a message on the bottom the display saying ''ACC not available'' This isn't a problem at all. You will need VCDS cable to deactivate this function/code out ACC function from the cluster. To do that: - switch ignition ON - plug VCDS cable in - go to [17] Instruments - then Security Access - click on the box where you need to type in Security Cody in order to get your code in a pop up window and type that in. Security Code is needed in order to enable Adaptation functions - click Do It - then go Adaptation and select ''ACC'' from the drop down menu - change Test Value from 1 (ACC active) to 0 (ACC inactive) and press TEST and then SAVE and OK to save. - Exit control module and VCDS and you are done. No more message ACC not available BEFORE Coding-out ACC from the cluster AFTER Coding-out ACC and test drive in CC mode where CC Green Symbol isn't present anymore It's good to have ACC-ready cluster in case you have no ACC and thinking about retrofitting it at some point in the future. I'm not the biggest fan of CC or ACC only because I like having full control of the throttle even on motorways, but it was a good deal to buy ACC wide dis cluster for £110 hence I've got one. Tomorrow I will write a guide inc. photos of how to swap clusters. I hope someone will find this guide useful ![]() >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> REMOVAL GUIDE Disconnect air vent illumination Remove decorative trim
2006 D3 S8 5.2 V10 Ceramic Brakes, Bang&Olufsen, DTV, DAB, Rear Camera, BT, TPMS, Soft Close, Auto Boot, AMI , 4 Zone AC, Home Link, All Electric Blinds, Fingerprint, Ski Hatch, Black Extended Leather, Heated Sport Seats, Alacantra, Carbon Trim inc Aluminium Pack 2. 2015 A3 S line 1.4 TFSI - for the missus to keep her away from my car. Standard S-line equipment, no extras. 2006 D3 A8 3.7 V8 - SOLD but not forgotten Last edited by M-A8; 17th November 2014 at 08:38 PM. |
Stunning work Marcin.
You rule. ![]() |
Got there in the end, looks like mine now.
Good work Marcin
Did you get the MPH display in the middle of the DIS?
Del ![]() |
Cheers David, Mannyo and Del
![]() Del, no or not yet. Will look tomorrow at all Adaptation channels and see if I can activated somehow or possibly this function appeared in MMI under Instrument Cluster in Trip Computer 1 and 2 selections of options to display after installing wide dis cluster. Is it know for this option to be available on models with MMI 2G??
It works on mine but that was always widescreen from new, but if you need to compare settings you only need to ask
Del ![]() |
If I don't get anywhere tomorrow you can rest assured that I will ask
![]() ![]() Also, I remember you can get in VCDS a tick menu where you can select and deselect certain options so I wonder if this is the case with MPHs. Also, it could be a Green Menu option/tick ?? Will update everyone tomorrow after taking some photos for the cluster removal guide ![]()
I've done the same thing as you Marcin and installed a widescreen ACC DIS dash in one of our D3 LWB's and I've got the ACC coded out also like you. I'm struggling to get the Large speedo readout in the DIS too, we've looked a fair bit and I'm beginning to wonder if it's not possible on an ACC dash, let me know if you solve it
Cracking job.
I really want a widescreen DIS. Even more after seeing yours and Architex-MA8tey's A8. I drove a S3 with that enabled and it was lovely. I thought the speedo display for the 2nd facelift clusters?
Morning all
I did wonder if that isn't the case, but Del's S8 is pre 2009 and he has it. Maybe it only works on cars with ACC actually installed and other standard bits like lates MMI ver etc. ??? I will have to dig through Adaptation channels and other settings and Hidden Menu possibly as well, i wouldn't be surprised Scott if that setting needs to be ticked somewhere there we had to enable Instrument Cluster menu after MMI update.
