Old 23rd January 2015, 08:41 AM
beastboxes's Avatar
beastboxes beastboxes is offline
Default no brake light issue
Hi guys i recently had some water ingress due to the clogged drip nipples common issue since then ive had problem with the passenger side rear cluster, i have no side light on the boot section ive tried replacing the bulb, the fuse and no joy. i also have no brake light on the left side also tried fuse and bulk replacement to no joy.
Anyone have any idea?
Old 23rd January 2015, 09:18 AM
Yes, I get this now and again. The contacts with bulbs are often the issue with mine. A quick dust with wet and dry on the bulb and the light contact and a gentle bend upwards of the contact in the light unit sorts it.
Old 23rd January 2015, 09:49 AM
I've got a spare bulb holder for the outer lens - not sure if they're linked electrically with the inner?
