Old 10th February 2015, 11:43 AM
Just seen your location:
Check out advance transmissions in Billingham. I've used them before with no issues
Old 10th February 2015, 05:16 PM
tonyt102's Avatar
tonyt102 tonyt102 is offline
Its Les at Advanced Transmissions in Billingham. Spoke to him today and he said pretty much the same as you Ian. He even remembers my old Alpina and last S8 from years ago! Can't fit me in until a week Monday unfortunatrly.
Old 4th March 2015, 03:51 PM
tonyt102's Avatar
Finally all sorted. Looks like the box had been leaking for so long that the level was too low. Had a replacement prop end seal fitted along with a full flush and service and it's fine now.
Old 4th March 2015, 04:03 PM
Good result - Was that with Les ?
Old 4th March 2015, 04:41 PM
There are four separate oil chambers on these boxes. The leak from the rear output shaft seal you talk about is a common issue.
Old 4th March 2015, 10:19 PM
tonyt102's Avatar
Yes, Les at Advanced Transmissions. This is the 4th job he's done for me and his knowledge is great.
Old 19th April 2015, 08:52 AM
tonyt102's Avatar
Unfortunately, the cheaper alternative of a service didn't work. All was going well until I gave it some beans then when coming though the village at slow speed, I went to accelerate and the engine revved to around 2500rpm then bang. It went into limp mode
Ended up having a full refurb including torque converter and it feels silky smooth now.
Old 19th April 2015, 12:20 PM
tintin tintin is online now
That was basically my experience. The good news being that after having the proper job done, it's been fault free ever since - i.e for more than 2 years.
