Old 28th April 2015, 07:29 PM
I actually found excuse to remove the front bumper and made the xenon replacement job a 5 minutes one
About the CAN BUS, well, I could argue here a little, I have quality £15 a pair can bus LEDS as sidelights along CREE LEDS as DRLS for something like 3 years now !!!
No issues with overheating and melting, and since having them wired together with DRLs they are always on from the moment you press START.
I also have CAN BUS LEDs fitted all over the car for almost 4 years now, and not a single issue, faulty LED, burned or overheated fitting. 4 years !!! and I spend a lot of time on many occasions working on some mods or whatever.
Yes, CAN BUS Leds are probably unnecessary, but I'm just speaking from experience.
Old 1st May 2015, 11:01 AM
centurion centurion is offline
cheers... do you have an error on the dash for using LED's?
Old 1st May 2015, 01:23 PM
Hello mate
No, if you bridge sidelight's positive wire with positive on DRLs(assuming you have DRL which you would on Bi-xenon headlights, and have P21W LED cree leds fitted as well as DRLs) then all you do is changing coding via VCDS in [09] from Bi-xenon with halogen drl lights to Bi-xenon with led drl light and that's it.
No errors, no resistors, and leds will also dim with main beam on as they to on oem led headlights.
