Old 31st January 2010, 10:01 PM
A8chris
Guest
Posts: n/a
Default Red light across gear dispaly
oh...**** i hope this isn't gonna be expensive !
last couple of 30+ mile runs the gear display on the dash has turned red on the background and not allowed me to use the triptronic on the lever or the padels on the steering wheel.
both times i the fault has gone away by its self or when i have stopped the engine and started it again.
just been through the manual and can't find anything related to this so has anyone had or ehard of this before ???????????
Old 1st February 2010, 08:54 AM
builder22 builder22 is offline
Hello there,
When that happens on my D2 it indicates that the car is gone into Limp mode i.e. stuck in 3rd gear.
I’m sure some of the more knowledgeable folks will be along soon to suggest possibilities.
Niall
Gone, but not forgotten...
2000 A8 4.2 Quattro – Green, S8 18’s, Xenons, PhatBox, and loads of other toys.
Old 1st February 2010, 03:22 PM
Oli18's Avatar
Oli18 Oli18 is offline
Hi A8Chris,
I take it from your picture that it's a D3? Can you give some more info on engine (and if you have it, gearbox)?
Thanks,
Oli
Audi A8/S8 D2 Flickr Group
Old 1st February 2010, 04:15 PM
A8chris
Guest
Posts: n/a
its a 53 reg D3.....4.0ltr diesel....with the 6speed triptronic auto gearbox.
it still goes through the gears ok with this light on in auto just wont let you manually shift
Old 15th February 2010, 09:10 PM
Interesting.... Whats the mileage on the car ?
Old 16th February 2010, 08:14 PM
A8chris
Guest
Posts: n/a
its got 73,000 on it.........not done it now for 2 weeks.....and have been driving it fairly hard :-)
was told by someone who used to have a rs6 its something to do with the constant self monitoring..?..see's something it doesnt like..?....goes away when checks are ok ?
Old 23rd February 2010, 07:52 PM
A8 Doc A8 Doc is offline
It's desperate for an oil change basically!
Get it changed ASAP with the correct oil and get your gearbox module updated with the latest software.
Fingers crossed you should be ok.
Old 24th February 2010, 08:16 PM
A8chris
Guest
Posts: n/a
engine and gearbox oil or just one of them ?.....how much are we talkin for the update ?
Old 29th March 2010, 08:07 AM
Gearbox oil change, sorry for not replying earlier.
£150 from Audi for the software update normally.
It's well worth doing.
Stop driving it hard whilst it has a problem too!!!
Old 5th October 2010, 07:00 AM
jmw748 jmw748 is offline
I'm not scare-mongering, but my 02 S8 did the same thing twice over the priod of two weeks, 15 months ago.
It is the gearbox going into limp mode and not a good sign. This happened 4 weeks AFTER I'd had the gearbox serviced as a precaution. The box subsequently failed and I needed a 2.5K rebuild. Ian will recall that it started a debate about whether you should bother with oil changes on a sealed for life unit, as mine was fine until I 'disturbed' it with a service. Chester Auto Transmissions said I had probably upset the balance of old oil, crud and the seals!
At best, you might have a gearbox ECU fault or a dodgy solenoid, but looking at the amount of 'boxes that have failed here after the all red display, I'd be saving my pennies. VAGCOM will give you a great steer with a gearbox fault code.
Really hope it's something minor, but I no longer trust ZF 'boxes with or without pre-emotive servicing.
Fingers crossed for you mate.
