Old 4th June 2015, 10:06 AM
Default Explanation of brake pad wear warning light (and MOT)
Can anyone explain exactly how the brake pad wear system works on an FL D2?
Mine came on part way home from The Meet, but went off after an overnight park up at home. Then came on somewhat later. Visually all pads look OK with a fair bit (several mm) left though the front discs are badly scored and will need replacing.
It seems to stay on once on but isn't on after an ignition cycle, presumably a "lock" somewhere that resets after an ignition off.
Nothing showing on VCDS so I'm guessing this is simple circuits/relays or similar.
After hearing various tales about dodgy wiring near the brakes or (worse) deeper in the car I decided to test it yesterday as I had a couple of 40-mile journeys to make.
It stayed off through many miles of driving as long as I only braked gently and used the gears/engine to slow down most of the time. Corners, bumps and other movements had no effect, ONLY applying the brakes reasonably firmly.
So how exactly does it work - e.g. wires embedded in the pad that are shorted by the disc?
And is this an MOT fail or just advisory - assuming the brakes otherwise work OK. Mine is due fairly soon I think.
Old 4th June 2015, 10:32 AM
Name:	brake pards wear.png
Old 4th June 2015, 10:33 AM
The wires are embedded in the pads and short out on the disc when worn to the prescribed level. Though what causes your erratic problems I cannot guess.
Old 4th June 2015, 10:35 AM
That diagram is it. A single wire that runs from the instrument cluster through both the front brake pads and back to an earth.
Any wiring fault, nick, loose connection, rubbing, fault pad etc anywhere in the circuit, and the light comes on.
Its common to hardwire it to ground behind the instrument cluster to stop it false reporting if you have an issue other than worn pads...
Old 4th June 2015, 10:40 AM
David, I wouldn't describe mine as erratic, it's probably just a wire in one of the pads which is just exposed so only making contact when braking firmly.
So, reading that, both sides need to be worn as they are in series?
Any comment re MOT?
Old 4th June 2015, 10:42 AM
Basically, the cluster is constantly monitoring pin 17. Normally it should always be grounded, like on the picture. If cluster senses that there is no ground (at least for a split of second) you will get a warning light until you switch off the ignition again.
The disc eats into a wire and eventually breaks the connection of the pin 17 to the ground.
Intermittent warning light with good break pads usually means oxidised contacts in the electrical connectors between the brake pads and harness of the car. See T4ad and T4ae on the picture.
Remove the wheel, trace the cable from brake pad into the car. Find the 2 pin connector, disconnect it (you will need a flat screwdriver to unlatch it) and inspect contacts within the connector. If you see green or white oxidation, then remove it. Also, make female side of connector tighter by squeezing contacts. You'll need a needle-shape tool for that. I used the dentist tool that you can buy on eBay for this. Before assembling the connector back please put some conserving non-conductive grease there to prevent future oxidation. You will never have the problem again.
Old 4th June 2015, 10:53 AM
OK, thanks, that makes more sense.
Given that it's ONLY applying the brakes that triggers the warning it suggests a poor contact close to the moving parts, i.e. the calipers, so first suspect is the local plug/wiring.
Old 4th June 2015, 02:46 PM
I started getting this warning just before setting off to the meet. If you or I are really unlucky a wire can break somewhere between the connectors and then its a real pain to find where it is broken underneath the insulation, or maybe if this is the case best to replace the whole wire. You can easily test which side with a continuity meter (pad side or car side when connector is unpluged).
I think someone on here has had to replace the car-side wire before.
Old 4th June 2015, 03:09 PM
Are the connector plugs accessible by turning the steering or does it need jacking up and the wheel taking off?
Old 4th June 2015, 03:55 PM
you need to remove the wheel to get to connectors in my experience.
