Old 26th June 2015, 04:13 PM
Question Cars - cause of cancer
If this is kosher why hasn't this become common knowledge via
government sources? Any feedback ...............?
This one is for all to read and then share...might help save a life.
Now this is very interesting! My car's manual says to roll down the windows to let out all the hot air before turning on the A/C. WHY ?
No wonder more folks are dying from cancer than ever before. We wonder where this stuff comes from, but here is an example that explains a lot of the cancer-causing incidents.
Many people are in their cars the first thing in the morning, and the last thing at night, 7 days a week.
As I read this, it makes me feel guilty and ill. Please pass this on to as many people as possible. Guess, its not too late to make some changes.
Please do NOT turn on A/C as soon as you enter the car.
Open the windows after you enter your car and then after a couple of minutes, turn ON the AC .
Here's why: According to research, the car's dashboard, seats, a/c ducts, in fact ALL of the plastic objects in your vehicle, emit Benzene, a Cancer causing toxin. A BIG CARCINOGEN. Take the time to observe the smell of heated plastic in your car when you open it, and BEFORE you start it up.
In addition to causing cancer, Benzene poisons your bones, causes anemia and reduces white blood cells. Prolonged exposure can cause Leukemia and increases the risk of some cancers. It can also cause miscarriages in pregnant women.
The "acceptable" Benzene level indoors is: 50mg per sq.ft.
A car parked indoors, with windows closed, will contain 400-800 mg of Benzene - 8 times the acceptable level.
If parked outdoors in the sun, at a temperature above 60 degrees F, the Benzene level goes up to 2000-4000 mg,40 times the acceptable level.
People who get into the car, keeping the windows closed, will eventually inhale excessive amounts of the BENZENE toxin.
Benzene is a toxin that affects your kidneys and liver. What's worse, it is extremely difficult for your body to expel this toxic stuff.
So friends, please open the windows and doors of your car - give it some time for the interior to air out -(dispel the deadly stuff) - before you enter the vehicle.
Thought: 'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others.’
Old 26th June 2015, 04:28 PM
Solar sunroof. Fixed.
Old 26th June 2015, 04:29 PM
You might want to read this too Marcin, in particular the part about smoking.
Interesting it can also be found in soft drinks???
https://en.wikipedia.org/wiki/Benzene#Toxicology
Old 26th June 2015, 04:49 PM
I say bogus
If your dashboard is made of, say, ABS, then it can emit benzene. Maybe it can emit ABS molecules which may also be unhealthy. A lot of D2 plastic parts are made of ABS+PA mix, like bumpers, etc. Not sure about interior trim.
More reading definitely needed.
http://www.thenakedscientists.com/fo...?topic=37634.0
Better stop filling up Marcin, its in the petrol
Old 26th June 2015, 05:03 PM
Guys. I'm not trying to scare anyone or saying this is true. Just sharing an email I have received from a friend of mine.
I'm more worried about food this days, there is more very unhealthy crap in it than in a car and we consume it everyday.
Old 26th June 2015, 05:34 PM
Living is harmful, everybody dies from it.
Old 26th June 2015, 08:57 PM
Top comment
In Serbia we call petrol Benzin, I wonder why. I think it used to have a high % of benzene in it, maybe as high as 40%? Nowdays the web says they put only around 3% in the UK.
Old 26th June 2015, 09:51 PM
Here is what "Snopes" has to say about this:-
http://www.snopes.com/medical/toxins/benzene.asp
Last edited by tc4332; 27th June 2015 at 12:18 AM. Reason: link had failed, now OK
Old 26th June 2015, 10:37 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Your birthday is your death sentence.
I'm here for a good time, not a long time.
Everything is bad for you in one or the other.
There's toxins in almost everthing we own.
There's to much sugar, to much, to much fat, this is bad, that's going to kill and this should be avoided.
Just go careful and enjoy your life.
No point worrying about what's going to kill you the quickest.
[center]
06 3.0TDI Quattro:
Options:
Old 27th June 2015, 06:19 AM
Don't forget Dihydrogen Monoxide, that's the biggest killer!
Each year, Dihydrogen Monoxide is a known causative component in many thousands of deaths and is a major contributor to millions upon millions of dollars in damage to property and the environment. Some of the known perils of Dihydrogen Monoxide are:
  • Death due to accidental inhalation of DHMO, even in small quantities.
  • Prolonged exposure to solid DHMO causes severe tissue damage.
  • Excessive ingestion produces a number of unpleasant though not typically life-threatening side-effects.
  • DHMO is a major component of acid rain.
  • Gaseous DHMO can cause severe burns.
  • Contributes to soil erosion.
  • Leads to corrosion and oxidation of many metals.
  • Contamination of electrical systems often causes short-circuits.
  • Exposure decreases effectiveness of automobile brakes.
  • Found in biopsies of pre-cancerous tumors and lesions.
  • Given to vicious dogs involved in recent deadly attacks.
  • Often associated with killer cyclones in the U.S. Midwest and elsewhere, and in hurricanes including deadly storms in Florida, New Orleans and other areas of the southeastern U.S.
  • Thermal variations in DHMO are a suspected contributor to the El Nino weather effect.
