Wife reckons it fell from the near side door onto her foot as she got out of the 8. I'm not so sure...
Door hinge pin? from the lower bracket with 3 pins?
sorry just realised you have a D3 not a D2. |
I think I have its identical twin! I believe it is from the front door pocket but I need to have a closer look at mine before I can say for sure....
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment ![]() 2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot 2022 Mercedes EQC 400 Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS 2008 A8 3.0 Tdi sport, B&O |
Thanks for the replies.
Just had a butchers in the dark with a torch. Can't see where it may have come from, but don't have access to the near side at the moment. Curious.
From memory the top hinge is the smaller one and could have a pin like that, but it does look small in the photo. If it is from the hinge assembly it'll be obvious, but be careful as the door could drop. The top hinge pin has a grub screw.
I'd expect the pin to be pushed in from the top so even if it were to come loose it could never fall out, but that might not be the case. Also worth checking the glove box hinge?
I think its the door pocket stop.. normally has a white rubber grommet over the top.. if you pull your pocket out you will see them on there
Seems I've lost the pin. Oh well. Maybe we'll never know!
Well, the hinged door pocket is loose, so that's where the pin came from. Best try and find it.
Ok. I found the pin again, and returned it to the hinge of the door pocket. Turns out part of the plastic hinge had snapped.
All back together again with some loctite and zip ties. ![]()
Ok. I need to put mine back also. Did you have to remove the door card or the door pocket?
