Old 7th August 2014, 01:14 PM
Lyons Lyons is offline
I got a camera a year ago. It was £17 and pretty rubbish and was a fake of a decent model.
Just changed it for a G1W a couple of weeks ago and thrilled to bits with it.
http://dashcamtalk.com/g1w/
Whichever one you get, watch out for inferior fakes/clones.
I painted the silver lens-ring and light with matt black paint but the current version is all black anyway.
Here is one of my clips... https://www.youtube.com/watch?v=nnOKQO86KN0
That looks 100%. Any photos of yours fitted?
Old 8th August 2014, 09:53 AM
Where did you get it to make sure it wasn't a fake?
Old 8th August 2014, 07:26 PM
2013 model
http://www.ebay.co.uk/itm/310752336819
or the 2014 model...
http://www.ebay.co.uk/itm/310830749213
Will take a snap but it's armagideon rain at the moment.
Old 30th July 2015, 08:17 PM
Default Leave on or not
Im in the process of fitting a dashcam too, question is do you leave it connected to power all the time.
Reason I ask is mine has the option of doing parking mode so if something is seen in the camera field of view it will record any incidents in my absence.
Will the camera be ok to be left on, and will the car shut off the power supply should the battery get low?
Old 30th July 2015, 08:25 PM
Mine (a Transcend DrivePro 220) has parking mode too, but it uses an internal battery. I have it powered from an ignition switched supply and it automatically switches to parking mode when I key-off.
Old 30th July 2015, 08:46 PM
Don't think mine has an internal battery, as soon as I pull power it informs me its shutting down...
Old 30th July 2015, 10:09 PM
Burnzybubbles's Avatar
Mine I had coming from an un-switched supply at the roof electronics, I would leave it plugged in if I was somewhere I wanted it left on, and if I was removing it from the car or the car was safe I'd just pop the plug out the top, I left it plugged in for over 7 days solid and due to the **** battery management system I nearly ended up with a flat battery once, I recharged the battery and unplugged it during most nights when the car was safe and never had the problem again.
Old 30th July 2015, 10:21 PM
Food for thought, think I will buy a separate battery saver to wire in line and have it connected to terminal 30 via a fuse.
Old 1st August 2015, 07:08 AM
Johnmed's Avatar
Johnmed Johnmed is offline
I wired mine into the fusebox, to a switched live. I'd rather not have the camera powered at all when the ignition is off. Better safe than sorry. I prefer to keep things simple given the number drains on the A8s battery.
2007 Mini Cooper S R56
Old 15th August 2015, 05:11 PM
I went the route of fitting an extra fuse into the drivers side panel and wired in a automatic cut of thats settable giving the option of having the camera on for parking mode but it will switch off when the battery is getting low to save a flat battery.
The reason I went that route is it became apparent that the battery manager would not have any influence on the situation should the dash cam be powered from a cigar lighter or the always on supply rail.
https://www.youtube.com/watch?t=1078&v=yzxh1YcWmXw
ID:	11697   Click image for larger version
ID:	11698   Click image for larger version
ID:	11699   Click image for larger version
