Old 6th August 2015, 02:56 PM
Default How faults are shown and what they actually are.
As most of you know an ACC install is happening over the next few days.
So not ever having an ACC car much less an 8 with it I had no idea what works with what and what has to be done in order for it too work.
The biggest thing that was bugging me was despite having the ACC comaptible gateway and distance stalk fitted to the car with various errors due to the radar not having comms was that the control head in the car refused to display the menu for adaptive cruise.
That along with the fact the when it reboots it shows an S6 logo "weird" is it just my car?
So today after having made a loom last night for the radar sensor I wanted to test the radar supplied by Dave at A8 parts before tearing the front off and actually fitting it and see if it worked and what else in the car worked or still complained.
Prior to fitting the radar there was no end of faults logged because i had coded all the modules for ACC but radar was still missing.
Happily once i connected the radar to the gateway and supplied power it immediately was apparent in the menu because adaptive cruise appeared at the top of the list
Anyway i digress, once the radar was in place i cleared all the codes to see what was remaining and needed attention see attachments
I then disconnected the radar and scanned again and you can see a whole host of errors that exist because comms to the radar is missing.
There is also a fault logged for left hand headlight saying no signal, that was because i had the fuse out.
The airbag fault was because the glovebox was removed.
Code:
Repair Order: interesting
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1D 1E 28
          34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76
          77
VIN: WAUZZZ4E77N009165   Mileage: 105450km-65523miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: Redir Fail!
   Part No SW: 4E0 910 552     HW: 4E0 907 552
   Component: 5.2L V10/4V FSI    ™0060
   Revision: 5AH11---    Serial number: AUX3Z0F8307595
   Coding: 01060003190F0260
   Shop #: WSC 00586 210 91538
   VCID: 5FCD4C658E49DCD9375-800A
2 Faults Found:
049717 - No Communications with Cruise Control (Front) Distance Sensor
               U0235 - 001 -
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 15:03:21
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 76.0∞C
                    Temperature: 57.0∞C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.938 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 15:03:22
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 76.0∞C
                    Temperature: 57.0∞C
                    Voltage: 11.938 V
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E1 910 156 K    HW: 09E 927 156 B
   Component: AG6 09E 5,2 FSI RdW 0020
   Revision: --H01---    Serial number:        0093558
   Coding: 0000001
   Shop #: WSC 02313 785 00200
   VCID: 2B55E8B58A717079EBD-807E
1 Fault Found:
006273 - Powertrain Data Bus: Missing Message
               P1881 - 000 - Acceleration Request
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 14:05:05
             Freeze Frame:
                    RPM: 0 /min
                    RPM: 0 /min
                    RPM: 0 /min
                    (no units): 30.0
                    (no units): 157.0
                    Temperature: 55.0∞C
                    T.B. Angle: 0.0∞
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 D    HW: 4E0 614 517 AB
   Component: ESP 5.7 allrad  H46 0500
   Coding: 0001927
   Shop #: WSC 02313 000 00000
   VCID: 24470389E7AFBF012A7-8071
1 Fault Found:
02083 - Message for Delay Request
            004 - No Signal/Communication
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 K
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0F8307595
   Coding: 0412672
   VCID: 58BF6779EB672BE176F-800D
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: ELV                 XXXX
No fault code found.
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
2 Faults Found:
01733 - Switch for Head-Rest Adj. Pass. Seat (E170); Down
            003 - Mechanical Failure - Intermittent
             Freeze Frame:
                    Fault Status: 00100011
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 105452 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 14:36:20
01732 - Switch for Head-Rest Adj. Pass. Seat (E170); Up
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 105452 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 14:36:20
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 732 L    HW: 4E0 035 729 A
   Component: Interfacebox    H43 3460
   Revision: 00000000    Serial number: 300IL067573450
   Coding: 0010002
   Shop #: WSC 00000 000 08192
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH03 0040
   Subsystem 2 - Serial number: 00000000019844
   Subsystem 3 - Serial number: 0117.08.060000000100010094ˇ
   Subsystem 4 - Serial number: 010094ˇ
2 Faults Found:
01319 - Control Module for Distance Control (J428)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 14:05:48
00384 - Optical Databus
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 6
                    Reset counter: 40
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 14:44:04
Address 08: Auto HVAC        Labels: None
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000106345
   Coding: 0057465
   VCID: 1C373B69DFDF87C1927-8049
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
   Component: ILM Fahrer      H15 0230
   Coding: 0133121
   VCID: 3663C9C141333D91843-8063
   Subsystem 1 - Part No: 4E2 910 113 C
   Component: Wischer WWS D3  H60 0440
   Coding: 00000036
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00141886
   Shop #: WSC 02313
Address 0E: Media Player 1 (R192)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H09 0700
   Revision: 00000000
   VCID: 275D1485569954190F5-8072
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276U7400564
   Coding: 0000001
Address 11: Engine II        Labels: Redir Fail!
1 Fault Found:
               U0235 - 001 -
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 105453 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 100.0∞C
                    Temperature: 62.0∞C
                    Voltage: 11.938 V
Address 13: Auto Dist. Reg
Cannot be reached
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H13 3710
   Revision: 91H13371    Serial number: 0037P0G02C1N
   Coding: 0431707
   VCID: 275D1485969954190F5-8072
   Subsystem 1 - Serial number: 63328RB40180B9CAT
   Subsystem 2 - Serial number: 63428RB40180B95FS
   Subsystem 3 - Serial number: 63528RB40180B9CCX
   Subsystem 4 - Serial number: 63628RB40180B95ET
   Subsystem 5 - Serial number: 63729RB401A1D1B6Q
   Subsystem 6 - Serial number: 63829RB401A2165DM
2 Faults Found:
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            010 - Open or Short to Plus - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 13:46:43
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 13:46:43
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenks‰ulenmodul H14 0040
   Coding: 0112151
   VCID: 65C15E8DAC158609FD9-8030
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 951 E    HW: 4E0 920 951 E
   Component: KOMBIINSTR. VDO H82 0520
   Revision: D03         Serial number: AUDID3F8000540
   Coding: 0048403
   Shop #: WSC 03329 002 104857
Address 19: CAN Gateway        Labels: 4L0-910-468.lbl
   Part No SW: 4L0 910 468 A    HW: 4E0 907 468 H
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 0100J075308013
   Coding: F5F5DFFF717E1E00
   Shop #: WSC 02313 758 00200
   VCID: 2D51E6ADB4657E49F59-8078
2 Faults Found:
02001 - Data-Bus Automatic Distance Regulation
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 4
                    Reset counter: 242
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 14:05:06
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 14:44:28
Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
   Part No SW: 4E0 910 218 A    HW: 4E2 905 218 B
   Component: FPI_1           H01 0020
   Revision: 01000102    Serial number: 22082006152159
   Shop #: WSC 00000 000 00000
   VCID: 1F4D0C65CEC99CD9775-804A
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8200979
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4E0 910 158     HW: 4E0 919 158 C
   Component: KLIMA-STG. FOND 017 0230
   Revision: 00000019    Serial number: 00000000046196
   Coding: 0000000
   VCID: 61C94A9DB83DEA29011-8034
Address 34: Level Control        Labels: User\TEST-34.lbl
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Coding: 0015510
   VCID: 2A5BEDB1858B697110B-807F
Address 36: Seat Mem. Drvr        Labels: None
   Component: Sitzmemory FS  H02  0010
   Coding: 4063342
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
   Component: MNS ECE         H48 1060
   Revision: 00000000    Serial number: 364I.067595623
   VCID: 3B75D8F57A11E0F97BD-806E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H05 0090
   Serial number: 00000625800101
   Coding: 0036068
   VCID: 1D31366DC4C58EC9659-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 D
   Component: T¸rsteuer.FS BRM005 0180
   Coding: 0032751
   VCID: 204F0F99F3B7A3214EF-8075
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
   Component: Komfortgeraet   H07 0010
   Revision: 00100007    Serial number:  W040609220062
   Coding: 0004861
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel   P14H06 0070
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H05 0020
Address 47: Sound System        Labels: None
   Part No SW: 4E0 910 466 B    HW: 4E0 035 466
   Component: BO_D3           H06 0180
   Revision: 20S00002    Serial number: 01109060005185
   Coding: 0000027
   VCID: 25411E8DEC9546093D9-8070
   Subsystem 1 - Part No: 4E0 910 465 A
   Component: BO_D3_SLAVE     H31 0100
   Subsystem 2 - Serial number: 01809060002932
   Subsystem 3 - Serial number: 0218.09.060000000100030011ˇ
   Subsystem 4 - Serial number: 030011ˇ
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 B
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000001772
   Coding: 0010101
   VCID: 1E333161C9C395D17C3-804B
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 D
   Component: T¸rsteuer.BF BRM005 0180
   Coding: 0032751
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
   Component: EPB  A32C0220   H02 0220
   Revision: A32C0220
   Coding: 0000731
   Shop #: WSC 00019 210 80940
Address 55: Headlight Range        Labels: 4F0-910-357.lbl
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Component: AFS 1           H01 0020
   Coding: 0000018
   Shop #: WSC 00019 210 90927
   VCID: 295912BD808D6269191-807C
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH02 0020
1 Fault Found:
02233 - Left Headlight Power Output Stage (J667)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 105448 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 14:05:05
Address 56: Radio        Labels: 4E0-910-541.lbl
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 396I+067546743
   Coding: 0000001
   VCID: 2E53E1A1B9630551CC3-807B
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 B    HW: 4E0 919 148
   Component: R0078 TVhybridTuner 0360
   Revision: R0H05000    Serial number: 76300700573201
   Coding: 0000003
   VCID: 224B0591FDBBB13158B-8077
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000020865
   Shop #: WSC 00000 128 00289
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  1121910408
   Coding: 344530393135313035412056413031313231393130343038
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: T¸rsteuer.HL BRM005 0180
   Coding: 0032751
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05
   Revision: 00050340    Serial number: 00000900047805
   Coding: 0212329
Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0630
   Revision: 00000000    Serial number: 00000610040141
   Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam.        Labels: 4L0-910-441.clb
   Part No SW: 4E0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J07100I
   Coding: 1121402
   Shop #: WSC 98765 666 38384
   VCID: 5CB77B699F5FC7C1527-8009
1 Fault Found:
03006 - Back-up Camera System not calibrated
            000 -  -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 242
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: T¸rsteuer.HR BRM005 0180
   Coding: 0032751
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08720624801512
   Coding: 0321008
   VCID: 23450095E2A1B83953D-8076
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H13 1130
   Revision: 00000000    Serial number: 00000007580460
   Coding: 0010900
   VCID: 2C57EBA98F7F7741E27-8079
End-------------------------(Elapsed Time: 04:09)--------------------------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 06: DTCs cleared
Address 07: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 0E: DTCs cleared
Address 0F: DTCs cleared
Address 11: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 1D: DTCs cleared
Address 1E: DTCs cleared
Address 28: DTCs cleared
Address 34: DTCs cleared
Address 36: DTCs cleared
Address 37: DTCs cleared
Address 38: DTCs cleared
Address 42: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 4F: DTCs cleared
Address 52: DTCs cleared
Address 53: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 57: DTCs cleared
Address 61: DTCs cleared
Address 62: DTCs cleared
Address 65: DTCs cleared
Address 67: DTCs cleared
Address 6C: DTCs cleared
Address 72: DTCs cleared
Address 76: DTCs cleared
Address 77: DTCs cleared
Code:
Repair Order: ACC instal
          77
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
Readiness: 0110 1001
   Coding: 0000001
   Coding: 0001927
   Coding: 0412672
   Component: ELV                 XXXX
   Coding: 4063328
   Coding: 0010002
   Coding: 0057465
   Coding: 0133121
   Coding: 00000036
   Shop #: WSC 02313
   Coding: 00141886
   Shop #: WSC 02313
Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
   Coding: 0000001
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4E0 910 561 F    HW: 4E0 907 561 F
   Component: ABSTANDSREGELUNGH03 0020
   Coding: 0041255
   Shop #: WSC 00029 210 86049
   Coding: 0431707
2 Faults Found:
            010 - Open or Short to Plus - MIL ON
             Freeze Frame:
                    Fault Status: 11101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 13:46:43
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 105453 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 13:46:43
   Coding: 0112151
   Coding: 0048403
Address 1E: Media Player 2 (R192)       Labels: 4E0-035-785.lbl
   Revision: 00000000
   Coding: 0000000
   Coding: 0015510
   Coding: 4063342
   Coding: 0036068
   Coding: 0032751
   Coding: 0004861
   Coding: 0000027
   Coding: 0010101
   Coding: 0032751
   Revision: A32C0220
   Coding: 0000731
   Coding: 0000018
   Coding: 0000001
   Coding: 0000003
   Coding: 0032751
   Coding: 0212329
   Coding: 1121402
1 Fault Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 242
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
   Coding: 0032751
   Coding: 0321008
   Coding: 0010900
End-------------------------(Elapsed Time: 04:06)--------------------------
ID:	11539   Click image for larger version
ID:	11540   Click image for larger version
Old 6th August 2015, 03:11 PM
Excellent post Del, very informative
Matt
