D3 - Common Faults Quick links to all known common faults and their solutions |
Symptom - ESP Light will appear on cannot be switched off without restarting the engine. Will appear under either light or hard braking.
Solution - Brake pedal switch. Remove lower driver side panel with Torx screwdriver. Remove air ducting and reach up. Undo electrical clip and twist the switch. Install switch and reverse the stripdown. |
