Go Back   A8 Parts Forum > General Natter > House and Home DIY
House and Home DIY Everything at home. Building, Renovating, DIY, green initiatives, mowing the lawn. Anything goes
Old 4th October 2015, 06:45 PM
Default SDS Hammer drill - Go cheap or branded?
I have few more demolition jobs around the house, especially an over engineered blocked fireplace that I'm reopening for a woodburner, and an SDS hammer drill with chisel would be a great addition.
I'm thinking of going cheap. Such as this one
http://www.ebay.co.uk/itm/251951964259
And if it dies after a year or so that's ok with me.
Or are their any merits to go with a branded Hammer Drill, like this one?
http://www.bosch-professional.com/gb...-d-8472-ocs-p/
Matt
Old 4th October 2015, 06:54 PM
The main difference you're paying for there is the latter is a rotary SDS. If you've got a decent normal drill then the cheapo ones should be fine. I've got a Screwfix/Titan one I've used a handful of times and it's worked well - it is blinkin' heavy but I guess it needs to be to work!
Old 4th October 2015, 07:15 PM
+1 on the titan, I have abused mine and its still kicking
Old 4th October 2015, 08:18 PM
+2 on the Titan. Mine's demolished fireplaces with ease but as Adrian says, its a heavy piece of gear.
Old 4th October 2015, 09:20 PM
Looks like I'm off to Screwfix to pick up the Titan
A pretty hard concrete mix was used, and it's solid! No stress fractures anywhere when it was used from the heat. Hopefully the Titan can make easy work of the fireplace.
Matt
Old 4th October 2015, 09:51 PM
Get the sledge hammer on it, great stress relief
Old 4th October 2015, 10:08 PM
Normally yes. That fireplace is on the party wall and they're a bit of a complainer... maybe I should just sledge it out
Matt
Old 4th October 2015, 11:10 PM
Haha they will hate the sds hammer more, that sound travels far.
Old 5th October 2015, 06:04 AM
I have the same cheapo Wolf one you linked to. Bought it a year or so ago. It's only had occasional use, but so far it's been great.
I find it better to check out products on Amazon rather than FleaBay since Amazon's reviews are product-based not seller-based. The Wolf does get very good reviews generally:
http://www.amazon.co.uk/Heavy-Rotary...dp/B00AZZYLGO/
I believe the Wolf is a rotary SDS too, as the description states. The one I have certainly seems to be (assuming that means it rotates, ie not a just hammer action).
Old 5th October 2015, 06:49 AM
Borys's Avatar
Borys Borys is offline
Had Titan products-never lasted longer then a month
I do have Dewalt sds and drill - 9 years and they are being abused
