Old 4th June 2015, 06:12 PM
Any comment re MOT?
I've done a bit of rummaging around online and looked at the .gov web site MOT manual too.
It seems that pad wear warning lights are totally ignored by the MOT.
Obviously the brakes do still have to work, which they definitely do.
Old 11th August 2015, 03:47 PM
Gone for MOT today, driven there by my friendly neighbourhood MOT tester. He texted me to say the pads REALLY ARE worn.
(and no, it's not a fail, or anything at all)
The front discs need replacing, which I know, so it seems that their uneven surface has just cut through one of the pads at the wrong place.
Still a reasonable amount of pad left over much of the surface, but it will all get done fairly soon.
Old 11th August 2015, 04:19 PM
Apparently the nearside inside pads were the worst worn and they also have the wiring, so possibly a sticking caliper or piston?
Old 11th August 2015, 06:49 PM
If the wire is partially exposed, you won't get the warning come on until you use the brakes and wear away anything stopping the pad wear sensor touching the disc. Usually lasts a little while like that before the light stays on as soon as you apply the brakes to move the gear selector
Old 6th October 2015, 02:17 PM
Finally had the front discs and pads replaced today.
£350 including VAT, most of which was for the discs.
Any recommendations for "bedding in" when they've both been changed together?
Old 6th October 2015, 04:14 PM
Don't drive like a bellend for a week and aviod heavy stops, job done.
Old 6th October 2015, 04:43 PM
Basically as above, try and avoid sitting on the brakes at traffic lights etc if you've just come off a motorway. Better to let the car creep a bit with light pressure
Depends on use but it doesn't take long to bed them in
Old 9th October 2015, 04:14 PM
oldnick oldnick is offline
getting an intermittant warning despite lots of pad left
just to be clear ....sensors on both front brakes ?[ not always the case }
Old 9th October 2015, 05:32 PM
I think it's a loop through both sides in series, inner pads.
Mine were worn more inside than out so "looked " as if there was still a fair amount left, but there wasn't.
